'97 D90 won't start - Defender Source
Old May 16th, 2008, 05:17 PM
defender1844
Amit Likhyani
'97 D90 won't start
It's not the battery. I don't think it's the fuel pump as that was replaced 8 months ago. It's definitely trying to turn over but nothing happens. How do I debug if this is a fuel pump again, a starter or something else.
The second reason I don't think it's a fuel pump is because last time the fuel pump went out I could try again a few more times later and it would start. This was instantaneous non starting but it sounds just like it did when the fuel pump went out.
Old May 16th, 2008, 06:31 PM
GYM's Avatar
GYM
Gary
97 SW
Not quite sure what you mean, "instantaneous non-starting".
Can you hear the fuel pump buzzing for a few seconds when you turn the key to the on position?
Old May 16th, 2008, 11:17 PM
defender1844
Amit Likhyani
Garth,
Thanks for the response. When I say instantaneously not starting I mean that last year when my fuel pump went out for the week prior I could try again a few times and get it to start. This time, all of a sudden it won't start and I can't try again a few times and get it to work.
I'll see if it buzzes when I turn the key. I'll also try shooting some ether or carb cleaner into the intake. If it starts temporarily it's the fuel pump.
Amit
90, 97, 97 d90, d90, start
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
95 D90 Can't start !!!!! Vadim Defender Technical Discussions 14 July 28th, 2004 03:52 AM
