97 d90 will not shift into low gear or diff lock - Defender Source
Old March 22nd, 2015, 07:23 PM
Noah97
Noah
97 defender 90 #59/300
97 d90 will not shift into low gear or diff lock. Any ideas already. Thank you Noah
Old March 22nd, 2015, 07:26 PM
phoenix37's Avatar
phoenix37
john
Hi Noah lots of threads on here about that issue.. try searching.. I just recently had that problem and it turned out to be the difflock switch plunger was stuck and wouldn't let it engage.
Old March 22nd, 2015, 07:53 PM
Wondering if its a lack of use issue. Might be worth taking the truck out for a nice long drive. Getting it good and hot then trying. Is truck new to you?
Old March 22nd, 2015, 08:11 PM
Noah97
Noah
I know it's from lack of use - I've owned it since new. I don't use it in low very often. I didn't understand what the plunger mechanism does or where the diff lock plunger is?? I'd love some guidance. First time dealing with the T-case. I already have the center ripped out. Thanks a bunch!
Old March 22nd, 2015, 09:19 PM
Noah97
Noah
Thanks Jeff
Tried that also I seperated the splined coller on the out side of the shifter and it moves all around. The arm that goes to the t-case is stuck. I am going to try the diff plunger.
Old March 22nd, 2015, 09:47 PM
Noah97
Noah
Thanks Jeff
Going to order the diff lock switch and see if that works
Noah
Old March 22nd, 2015, 09:53 PM
phoenix37's Avatar
phoenix37
john
Unscrew it half way out and see if that works.. no need to wait for the switch to try engaging it. fyi i ordered mine from Rovahfarm.
Old March 22nd, 2015, 09:54 PM
The solenoid is only for the high/low shifting. The diff lock should still work.
The solenoid should be thrown away.
Old March 22nd, 2015, 09:55 PM
Noah97
Noah
I do like the rovahfarm
------ Follow up post added March 22nd, 2015 06:59 PM ------
Thank you everyone for your help. Keep you updated
Old March 22nd, 2015, 09:59 PM
As John says, if teh switch is in the way, it does not need to be replaced, just adjusted. See the manual.
Old March 22nd, 2015, 10:50 PM
psykokid
Jake
1997 Disco
Noah,
You have two different unrelated issues. Since they are functions that are actuated off of the same lever people often relate them but they are separate functions.
-Diff lock wont engage
-Cant shift from hi range into low range.
On my 97 disco I had to remove the Hi-Low lockout solenoid as mine had failed closed and I couldn't shift into low range. On the 90 you have it easy since you can just remove the transmission tunnel and the round cover piece is right there and easy to access. On the disco you have to remove the shifter, center console and its still a PITA to get to the four 8mm bolts securing the cover plate.
As far as diff lock - Can you disconnect the linkage at the CDL nipple on the transfer case and lock the CDL with a wrench? If you can lock the CDL in that manner then your linkage just needs to be taken to bits and cleaned, lubed and adjusted.
Noah97
Noah
Jeff
Where is the solenoid (high and low) located.
Thank you
Old March 22nd, 2015, 10:54 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
If your dome light is burned out check the fuse...it also controls the solenoid.Don't ask me how I know.
Old March 22nd, 2015, 11:02 PM
psykokid
Jake
1997 Disco
Originally Posted by Noah97 View Post
Jeff
Thank you
High - low solenoid locaition is circled in red.
Old March 22nd, 2015, 11:07 PM
Jeff
Thank you
On top of the transfer case, in front of the parking brake.
Old March 22nd, 2015, 11:17 PM
Noah97
Noah
So then I just unplug it and throw it out.
Old March 22nd, 2015, 11:25 PM
Bill Larson
Bill Larson
But it is there for a reason...
Old March 23rd, 2015, 12:04 AM
Bill Larson
Bill Larson
Yes well I don't like those californication liberal views...mine is staying...I expected Smigle to pop out in that video...that must have been what middle earth was like before the "ring"!
Old March 23rd, 2015, 06:06 AM
Not being able to shift while moving remove a lot of functionality from the transfer case.
Old March 23rd, 2015, 06:46 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yea, the Safety police.
It was never there on the 87-88 RRC that had the same set up (ZF/LT230)
Please...think of the children...
Rent my
90, 97, 97 d90, d90
gear/diff lock stock thread sizes please! clasicmini80 Defender Technical Discussions 0 April 6th, 2014 05:00 PM
Will not get into reverse gear Landyman1 Defender Technical Discussions 2 August 19th, 2013 11:11 AM
Can't Shift Into Low Range rr1 Defender Technical Discussions 6 January 6th, 2012 11:32 PM
Rover Gear and a Beer KAM electric diff lock Fivespddisco The Vendors Loft 7 February 3rd, 2010 03:01 PM
Getting into gear, but not *moving*! chris72982 Defender Technical Discussions 3 February 9th, 2004 12:38 PM
