97 d90 will not shift into low gear or diff lock - Page 2 - Defender Source
Old March 23rd, 2015, 08:30 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Originally Posted by Red90 View Post
Not bengals able to shift while moving remove a lot of functionality from the transfer case.
I get that, but I don'y remove my toes for fear of stubbing them...
in the end it's personal choice.
Old March 23rd, 2015, 10:58 AM
Noah97
Noah
97 defender 90 #59/300
I read some place that you can cut or file down the tip of the solenoid and then reinstall. Is that true.
Old March 23rd, 2015, 11:08 AM
phoenix37's Avatar
phoenix37
john
i pulled my solenoid and tossed it… not sure its worth messing with
Old March 23rd, 2015, 11:10 AM
I've no idea why you would do that. You can remove it with no downside. Put it away and then it can be put back in at any time if you want things back to original.
Old March 23rd, 2015, 11:21 AM
On the Tcase, id pull it all together. You could try that on the Auto Shifter for a clean yet disabled installation.
-Jeff
What is the big deal with sticking the solenoid in a box and keeping it? Some people like Bill like original spec, so it can't hurt to give it to the next owner.
Old March 23rd, 2015, 12:29 PM
I have said to pull it, not throw it away.
Which is exactly what I said....
Old March 23rd, 2015, 12:55 PM
phoenix37's Avatar
phoenix37
john
i said i threw mine away….he certainly doesnt have to… my tcase came from a 98 disco and went into an 83 110 so there was no originality to be had...
Old March 23rd, 2015, 01:41 PM
Noah97
Noah
I pulled the solenoid and now it works. The solenoid did not move when I had it plugged in and shifted to neutral. Thanks guys for all your help.
Old March 23rd, 2015, 02:07 PM
psykokid
Jake
1997 Disco
Nice! Glad that you got it worked out. Any luck getting the diff lock to engage or are you still futzing with that one?
Old March 23rd, 2015, 02:15 PM
Noah97
Noah
Got the diff lock to engage but no light. Which I am ok with after owning the rover for 18 years I should know if it is engaged or not. Thanks again. This was my first time using a Land Rover forum and it was super helpful. Thanks again. Now onto the fix
Old March 23rd, 2015, 03:05 PM
The light is not actuated by the lever. It is actuated when the diff lock itself engages. The lever pushes on a spring. The spring pushes on the diff lock. You may need to turn corners both ways before the diff lock actually engages.
Old March 23rd, 2015, 05:11 PM
Noah97
Noah
Thanks guys everything is working great
90, 97, 97 d90, d90
gear/diff lock stock thread sizes please! clasicmini80 Defender Technical Discussions 0 April 6th, 2014 05:00 PM
Will not get into reverse gear Landyman1 Defender Technical Discussions 2 August 19th, 2013 11:11 AM
Can't Shift Into Low Range rr1 Defender Technical Discussions 6 January 6th, 2012 11:32 PM
Rover Gear and a Beer KAM electric diff lock Fivespddisco The Vendors Loft 7 February 3rd, 2010 03:01 PM
Getting into gear, but not *moving*! chris72982 Defender Technical Discussions 3 February 9th, 2004 12:38 PM
