97 D90 Timing and Altitude Performance - Defender Source
Old April 24th, 2006, 07:20 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
I understand those with distributors have had good effect by advancing the timing a few degrees to improve performance for trucks running at altitude. Has anyone modified the timing of a 97 truck? If so, please provide details - procedure and effect. Thanks. Mark
Old April 24th, 2006, 07:56 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Your 97 self compensates for the altitude. You may be able to get an adjustable chip upgrade where you can program in individual settings to a degree, but I have not seen one for a rover.
Old April 24th, 2006, 09:15 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
If it self-compensates, it does a poor job of it. Truck ran real well at sea level or there abouts. Up here it's a bit disappointing. I'm open to making some mods to get it to 'breath' better, but wanted to explore the timing option first. Thanks for the note. Mark
Old April 24th, 2006, 09:21 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
supercharger would do it. There are a few that have done it here...
Old April 24th, 2006, 09:26 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Thanks, Chris. I've read some of the posting on the superchargers. Right now I'm inclined to go down the route of head work, enlarging and lowering the stacks, and maybe a cam. However, wondering if the ECU can be modified to compliment the mechanical enhancements. Hate to go down that road only to be 'hand-cuffed' by the computer. Anyone else around that you can recommend besides PPR that can do this type of work? Thanks.
Old April 24th, 2006, 11:13 PM
There is no easy way of advancing the timing on a 97. The 97s have electronic ignitions, and the computer sets the timing off of a sensor looking at a 36 - 1 tooth gear on the flywheel ( crank positioning sensor).
I believe the 97 guys (or OBD2) run bigger injectors when increasing air flow to compensate since the ECU may not be able too.
90, 97, 97 d90, d90
