97 D90 Speedo adjustment - Defender Source
Old February 18th, 2010, 01:37 PM
ajtbussen
A J Bussen
1997 D-90 ST
I've got a 97 D90 with 4.11 and 285 70R16 tires. Can one adjust the speedo to the correct ratio?
If it aint moto it's worthless.
Old February 18th, 2010, 03:17 PM
Yes, if you take it to a speedometer shop or replace it with an aftermarket VDO, where you can adjust it yourself.
Old February 18th, 2010, 03:49 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Correct me if im wrong but I think 97s have a gear inside the T-case that drives the speedo still. There are a bunch of different toothed gears you can swap to. This is not as accurate as getting a VDO and getting it programmed to the correct speed, but it can be a cheaper way to go about it. How many miles per hour are you off?
there are:
frc3310 20 teeth
frc3311 21 teeth
frc3312 22 teeth
frc3313 24 teeth
Old February 18th, 2010, 06:03 PM
ajtbussen
A J Bussen
1997 D-90 ST
I,m almost positive that the 97 has the same sender as the discos VSS. My speed is off about 10 mph @ 60 mph real speed.
Old February 18th, 2010, 09:27 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
The real trouble is when it thinks you are going 100MPH and it cuts the fuel injectors off...
Old February 18th, 2010, 10:00 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
A Defender going 100 yeah right. lol
Old February 18th, 2010, 10:23 PM
Rugbier's Avatar
Rugbier
Gustavo
Dude, do you actually know how to retrieve messages on your Cell Phone ? *LMAO*
Call me
NO SIGNATURE
Old February 18th, 2010, 10:33 PM
crown14's Avatar
crown14
Verticalscrote
I can build you one if youd like
Old February 18th, 2010, 11:22 PM
CDeWan
Clay DeWan
5.3L beastie
100 in a defender is easy . You just have to get an ECU out of a classic that does not have the 85mph fuel cut. Now if you took your swaybars off then forget being a speed demon.
Old February 18th, 2010, 11:53 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Someone said something about a VDO speedometer? It uses the same mechanism as the old defender speedo? Any parts number? I need to renew some gauge and I already have VDO gauge. Would like to have a complete VDO setup.
Old February 19th, 2010, 12:25 AM
crown14's Avatar
crown14
Verticalscrote
But an RRC ecu won't do much good in a '97
90, 97, 97 d90, d90, speedo
speedo for 97 D90 ome mjekogian Wanted 2 February 14th, 2006 12:53 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
OEM MAF sensor from '97 D90.... dmarchand For Sale - Parts 4 June 18th, 2004 06:49 AM
97 D90 maxing out at ~70mph?? vnrover Defender Technical Discussions 3 November 10th, 2003 02:14 PM
