97 D90 Door rattles - Defender Source
Old April 29th, 2010, 09:20 AM
willr's Avatar
willr
WILL RAGSDALE
NONE
97 D90 Door rattles
I have a 97 D90 soft top that has a fiberglass hard top. I recently removed the fiberglass top for the summer and I put a badger fds 1 set up on the truck with the tonneau cover over the back. When I removed the hard top, I removed the rubber gaskets around the doors. My doors and the glass window top on the passenger side make a lot of rattling noise. Where can I get some trim pieces that work with the badger fds set up?
Will
Old April 29th, 2010, 10:22 AM
specops1526's Avatar
specops1526
Beluga '97 90
Have you tried to tighten the bolts that hold the door top on? Check the weather stripping at the bottom of the window. It could be deteriorated enough to allow the glass to rattle.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 29th, 2010, 01:14 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Simple: Leave the windows off for the summer!
Old April 29th, 2010, 01:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
so your doors have no rubber gaskets?
Old April 29th, 2010, 01:55 PM
You are supposed to leave the rubber door gaskets on the parts that are still there. I cut them at the joints of the hardtop to the door above the windscreen and between the tub and the hardtop.
Ron
Old April 29th, 2010, 02:18 PM
specops1526
Beluga '97 90
Ah, guess I didn't read close enough. Yeah, you need the weather stripping for ST doors.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
90, 97, 97 d90, d90, door, rattle
headers for '97 D90 mdmccallum Defender Technical Discussions 43 April 25th, 2005 10:23 AM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
OEM MAF sensor from '97 D90.... dmarchand For Sale - Parts 4 June 18th, 2004 06:49 AM
97 D90 maxing out at ~70mph?? vnrover Defender Technical Discussions 3 November 10th, 2003 02:14 PM
For Sale: '97 D90 ST-1791 Alpine White jwebster For Sale - Vehicles 0 September 30th, 2003 12:36 AM
