97 D90 check engine light - on now off? - Defender Source
Old January 28th, 2005, 08:15 AM
Eric_S
Eric
'97 D-90 ST #1507
Started it up after the little snow storm here in Boston and noticed about a cup of water came out of the tailpipe (wind must have blown the snow into the tailpipe) and the "check engine" light came on. Ran and drove fine. Drove it for last 3 days without a problem and yesterday the light went off. Should I be concerned? Can I still pull the fault code/codes?
Eric
Old January 28th, 2005, 09:39 AM
If no light I don't think there would be a fault sode but I am not 100% on the 97's with the OBD2. I bet it had something to do with the weather.
Old January 28th, 2005, 09:45 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
It read a an error, and was cleared by the GEMS system after several cycles without the code. You can read the code with an ODB2 and it will tell you what initially tripped the light.
Old January 28th, 2005, 10:17 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
It may be the O2 sensor. Code should tell you.
90, 97, 97 d90, check engine light, d90, engine, ht
Check Engine light Question? True or False? Hammertime Defender Technical Discussions 0 April 5th, 2009 10:39 PM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
low mileage 97 D90 on ebay Chris Cox Misc. Chit-Chat 2 November 26th, 2003 07:17 AM
For Sale: '97 D90 ST-1791 Alpine White jwebster For Sale - Vehicles 0 September 30th, 2003 12:36 AM
» Defender Registry
cjbenway
Roi
Bassi
Add your Defender
