97 D-90 Auto Transmission Shifting at Higher RPM - Defender Source
Old October 15th, 2006, 02:54 PM
parkcity4x4classic
Susan C. Daniero
We have a 97 Defender 90 that is shifting at higher rpm points than normal. When it is shifting it is a little rougher than normal. Has anyone had this problem? Any suggestions before I have a mechanic look at it?
Susan C. Daniero
Park City 4X4 Classics
Authorized Dealer-Campa All-Terrain™ Trailers
Authorized Dealer-TLC ICON™
Phone: (435) 731-0748
Website:
Utah Dealer #6541
Old October 15th, 2006, 02:57 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
have you adjusted the kickdown cable?
Old October 15th, 2006, 02:58 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
First things I would check are the level and condition of the fluid. If those are good, I'd look for broken or rotted vacuum lines leading to the transmission as well as on top of the engine. Then I'd have a tranny shop do any band adjustments and check the pressure modulator. Doesn't sound yet like it's worn bands or clutchpacks, but then again I'm not a tranny guy.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 15th, 2006, 03:04 PM
parkcity4x4classic
Susan C. Daniero
We haven't run any diagnostics on it yet. I just noticed it yesterday. We will take a closer look @ it tomorrow. Thanks for the suggestions, hope its nothing major!
Susan C. Daniero
Website:
Utah Dealer #6541
Old October 15th, 2006, 03:09 PM
Hans's Avatar
Hans
Hans Haase
Is it on the '94 on your website? My guess then is probably just needs adjustment, conversions sometimes don't get all the bugs worked out fully if they are done at home and dealerships usually don't look at transmission adjustments unless you specify that you want them done. I'd maybe go through the full adjustment process straight from the manual to make sure everything is done to the proper specs.
-Hans
My oil line fix
Old October 15th, 2006, 03:22 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
could also be a vacuum hose problem. Check all hoses..
Old October 15th, 2006, 03:46 PM
parkcity4x4classic
Susan C. Daniero
No, its not the 94 on our website. It is a 1997 that we bought from Northern Califonia. It's not ready for sale yet, until we check it out thoroughly. The 94 is an automatic conversion, when we received it we had new breather tubes installed & replaced the internal oil pump in the transmission. That one shifts great, that's why I know this one needs some type of adjustment or repair.
Susan C. Daniero
Website:
Utah Dealer #6541
Old October 30th, 2006, 05:35 PM
parkcity4x4classic
Susan C. Daniero
Smile Kickdown Cable
Thanks for the suggestions! They really helped my mechanic diagnose & repair the problem. Jonathan you are the winner! The kickdown cable needed adjustment. It shifts great & with such a simple repair.
Susan
Susan C. Daniero
Website:
Utah Dealer #6541
90, 97, d-90, transmission
WTB 97' D90 auto transmission cooler pendy Wanted 15 September 28th, 2005 08:12 PM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
ZF Auto Transmission 1997 Disco 60k miles castlerock4x4 For Sale - Parts 5 February 27th, 2004 06:10 PM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
