97 AC Unit: How to remove the evaporator casing? - Defender Source
Old July 26th, 2016, 05:53 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
My 97 AC is dripping condensation from the back of the small plastic elbow coming out of the evaporator casing (it's not running thru the elbow into the rubber drain hose as it should). I'm trying to get the evaporator casing out in order to inspect where the leak is coming from.
Service repair no 82.25.20 from the 1997 NAS Workshop Manual seems to cover this, but darned if I can figure it out. I've removed the three nuts securing the housing, but can't seem to get things beyond there.
Any tips from someone that has done this?
Old July 26th, 2016, 06:04 PM
brettm's Avatar
brettm
Brett
oh - nevermind - I missed the part about you have to disconnect the union on the return pipe to get it out; which means discharging the refrigerant. Messing with the refrigerant is beyond my skillset - I think it's time to send it to the shop
Old July 26th, 2016, 06:12 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Have you tried blowing it out with compressed air to clear the blockage?
RDavisinVA
Old July 26th, 2016, 06:25 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yep, it will then pull up and out. The pipes through the bulkhead are naggly...
Rent my
Old July 27th, 2016, 11:42 AM
brettm's Avatar
brettm
Brett
blow air into the elbow? won't that push any blockage up into the unit? i can't really see what is beyond the elbow unless i get into the evaporator unit. the rubber hose is new and has no blockage.
Old July 27th, 2016, 11:54 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
There's nothing much in there.
Just a radiator....the water just collects in the bottom *tray* area.
I'd try blowing the compressed air first, too.
Rent my
97, ac
WTD LHD Elite Evaporator unit rdavisinva Wanted 5 July 1st, 2016 11:46 AM
Glowplug stripped out of casing ini88 Defender Technical Discussions 20 March 18th, 2013 07:52 AM
How to remove channel to remove seat skins Campbell Defender Technical Discussions 2 October 23rd, 2009 05:47 PM
1997 Defender 90 Rear Axle Casing Steve Friedman Wanted 3 March 8th, 2009 07:33 PM
Axle or axle casing Departing90 Wanted 0 May 29th, 2007 08:45 PM
