97' 90 with 4.6 having problems - Defender Source
Old May 11th, 2010, 01:22 PM
nomadic90's Avatar
nomadic90
Ryan Quandt
97 defender 90
I installed a 4.6 in my 1997 90 and I keep having the same p1313 bank A misfire code. I then started having o2 sensor codes and beow threshold catalytic converter codes. I have done all of the following work to try and solve my problems.
-new spark plugs and wires
-new coil pack
-all new o2 sensors
-brand new catalytic converter
I just installed the sensors and catalytic converter a day ago ran fine all day but this morning starting the truck (it was a colder spring mornng) the check engine light was flashing at me and the code p1313 came back on.
I noticed the engine has been having a kind of ticking noise in cold weather right after it's started, but goes away when it warms up. That's usually when the check engine light starts flashing.
The other thing I noticed is that at highway speeds there seems to be a flat spot in the rpm's.
It will cruise at 60 no problem but if you want to go faster to pass a car it just stays in the 2000 rpm range so the transmission won't shift up. Sometimes I can get it to jump up to 3000 rpm's but not always. I've had the kick down cable adjusted but didn't help any.
Otherwise the truck starts, runs, and idles smooth.
Not sure what to look at next.
Ryan
Old May 11th, 2010, 01:57 PM
I'm sure I will be of no help, but...
There is a problem with the 14CUX ecm in that they just lose a whole bank with no apparent reason. Worky one day, no worky next day. I have three of the damn things sitting in a box and they're all f'd. That said, you would be having serious issues if only one bank were firing, as only 4 cylinders would ever go bang; 2 per revolution, which you'd certainly know about. Doubt it is an ECU issue. Don't even know if yours is 14CUX, so that shows what I know.
Anyway, your o2 sensors have nothing to do with whether the engine fires or not. All they do is give the ECU feedback AFTER the warm up phase as to whether the engine is running rich or lean. Keeps the 14.7:1 air fuel ratio constant regardless of load.
I would begin by checking that all your grounds are clean and tight. There are some on the back of the cylinder head so look there too. Be sure you have a fresh fully charged battery and the connections are clean and tight. You'd be amazed how many problems are due to low voltage/bad grounds.
Report back after checking all the connections.
Re: cold ticking. Probably a tappet. I currently have one bad one in my own truck. First thing to try is Marvel Mystery Oil. Change the oil and add one quart in the engine and run it for a few hundred miles to see if that frees up the faulty lifter. If not you'll need to do some simple surgery to replace all the cam followers.
Old May 11th, 2010, 02:31 PM
I know nothing about the 97 other than it's not 14CUX
Old May 11th, 2010, 04:28 PM
nomadic90's Avatar
nomadic90
Ryan Quandt
97 defender 90
The engine block was completly rebuilt with resurfaced heads, new lifters, valve springs, RPI camshaft, etc. Has just over 3,000 miles on it now. I've already done 3 oil changes on it for the break in.
Ecu is the original 4.0 and has not been rechipped at all.
Ryan
Old May 11th, 2010, 05:57 PM
Ryan
Means absolutely nothing. If the tappet was bad when installed, it is still bad today. There is no way to visually inspect a part like that before you plop it in and be able to say it's good or no good. Guess you'll be taking off the intake and replacing the lifters some time in your future.
Old May 11th, 2010, 08:08 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The ticking noise is normal--it is caused by the rocker shafts and the hydraulic lifters until the oil pressure has built up--and then it goes away--usually in the 10 second or less time.
It could also be your alternator--I know this sounds funny, but if the zenier diodes are going bad, it can be leaking A/C current into your electrical system causing misfires and such. Just one thing to keep an eye out for. Usually this happens in the 2600 rpm range (for me at least) and had similar scenario.
Old May 11th, 2010, 10:43 PM
nomadic90's Avatar
nomadic90
Ryan Quandt
97 defender 90
Yes the ticking only lasts a few seconds on start up.
That's interesting to hear about the alternator. I suppose there is no way to test that if it only happens sometimes. Just install a new one and see what happens?
Ryan
Old May 12th, 2010, 12:01 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I do believe it can be bench tested at most auto parts stores--not sure if that checks for A/C, but it probably does. Just a rectifier circuit.
90, 97, problems, vin
95 or 97 Defender 90 front bumper d90boy Wanted 2 April 21st, 2010 09:48 AM
Wanted: ANR5508 ABS ECU for 97' 90 nomadic90 Wanted 0 April 12th, 2010 08:30 PM
97 4.6 Engine for sale d90-110 For Sale - Parts 18 March 27th, 2010 11:53 AM
97 NAS 90 in VA for sale Dopplemax For Sale - Vehicles 0 December 28th, 2009 05:10 PM
3.9 to 4.6 1995 D-90 boxerhips Defender Technical Discussions 5 January 25th, 2006 07:20 PM
