97 4.0L viscous coupling removal - Defender Source
Old May 4th, 2005, 11:41 AM
Has anybody done it? RN says that it unscrews counter clockwise and is not reverse threaded. Any help????
Once again, 1997 4.0 Litre motor....Thanks
Old May 4th, 2005, 01:26 PM
Sounds right as the 4.0 serp belt water pump turns the opposite way of the 3.9 V-belts.
Old May 4th, 2005, 01:40 PM
Great, I have been pulling as if it was reverse threaded. I'll give it a try this weekend. I hope by then my knuckle skin will have grown back.
Old May 4th, 2005, 03:15 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Put your wrench on it hold the wrench with one hand & smack it with a dead blow. Just like butter!
Old May 4th, 2005, 08:15 PM
Got it.......thanks. What a PITA! The electric fans went in very easy. One more question......if you don't use the 3 way switch, do you need to tap into the A/C compressor wiring??? Thanks.......
Old May 4th, 2005, 09:33 PM
I'll have to make a new diagram for the fans with no switch I'll do it at work tommorrow.
Belt removal on a 97 thelandroverguy Defender Technical Discussions 10 July 31st, 2011 09:41 PM
Viscous Coupling swap - anything I should know? Emerson00 Defender Technical Discussions 1 December 10th, 2007 10:24 AM
Viscous Coupling & Fan javelinadave For Sale - Parts 3 September 29th, 2005 01:06 PM
viscous coupling rover4x4 Defender Technical Discussions 6 April 26th, 2005 07:03 AM
My viscous coupling be broke! dboehme Defender Technical Discussions 6 October 6th, 2003 11:32 AM
