95 vss - Defender Source
Old July 18th, 2015, 10:05 AM
95 vss
ive had my defender going on 11 years now and 50k miles. it has been trouble free and a joy to own. i got my check engine light cherry popped last week, turned out to be a code for the VSS. i went through the steps and cleared the code with no issue. id been driving on the highway for about 45 minutes when the CEL showed up. no symptoms of poor running or idle etc what wouldve cause this code? a glitch in the matrix? truck runs extremely well.
please excuse my lack of punctuation and proper use of my native language
Old July 18th, 2015, 11:10 AM
Check out the VSS as per the manual and go from there. A dead VSS won't cause a lot of symptoms. Mostly it lets the EFI ECU switch between two idle modes. If it is in the wrong mode, you can have stalling issues as it does not know when you are stopping.
Is a Disco I VSS compatible with LT95 4-spd? Miller Defender Technical Discussions 14 November 1st, 2012 02:16 PM
VSS function Roverlab Defender Technical Discussions 12 February 9th, 2012 08:16 PM
Where is the VSS on a 94 D90? cgalpin Defender Technical Discussions 2 October 12th, 2007 07:50 AM
Help with VSS Malfunction Code Seriesman Defender Technical Discussions 8 December 20th, 2005 10:58 PM
97 D-90 Vss Help Sirfoss Land Rover Defender Technical Discussions 3 August 9th, 2004 08:11 PM
