95 RRC axle question - Defender Source
Old November 13th, 2014, 07:12 PM
Toughy
95 Yellow ST
So finally getting around to front wheel bearings on my RRC, with both front wheels off the ground when I spin a wheel in either direction it shudders ... Does this confirm bearings or something bigger?
Old November 13th, 2014, 07:43 PM
Toughy
95 Yellow ST
Edit: took bearings off and only shudders when I spin the shaft, gear oil is muddy and will be changed..,is this normal?
Old November 13th, 2014, 08:05 PM
My guess is that the bearings are bad and the preload needs to be reset.
Pics of HD rear axle vs stock axle? josh-man Defender Technical Discussions 22 July 4th, 2017 04:22 AM
1997 D-90 rear axle housing and 83' 110 front axle housing Tyler Wirken For Sale - Parts 0 January 3rd, 2012 06:31 PM
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
Axle or axle casing Departing90 Wanted 0 May 29th, 2007 08:45 PM
