95 rrc - Defender Source
Old May 11th, 2016, 06:35 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
95 rrc
Truck starts 1 out of 10 ignition turns. Batt, alt, cables all checked, assuming ignition. Any way to check with out pulling ignition?
Old May 11th, 2016, 08:01 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Do you mean the starter engages 1/10 times? Or it cranks, but won't catch 1/10 times
Old May 11th, 2016, 09:09 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Just a click, doesn't engage. When turns over starts right up. I can hear fuel pump running when engaged as well
Old May 11th, 2016, 09:12 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
How long since new plugs, wires, and cap & rotor?
Old May 11th, 2016, 09:29 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Less than a year, shucks can't post video of start
Old May 12th, 2016, 03:13 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Bosch starter? If so, Bosch made in Mexico or Bosch made in Germany? My made in Mexico died after two years with similar symptoms. My German unit has been perfect every time for the past 2!
Old May 12th, 2016, 08:27 AM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Hummm, good idea. Easier to pull starter and have checked vs risking cracked/warped dashed assembly / reassembly on ignition.
I'll try it, thanks
cellulararrest
Chris Snyder
If it's just clicking but not turning the starter then it's the starter solenoid. Either clean it out or just replace the starter.
But if it's a loud whack from under the truck, definitely the starter solenoid.
Old May 13th, 2016, 08:52 AM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Yep, bad starter. Wish they would try n fix rather then slap another one on, but sounds like bendix missing teeth.
RRC SWB 95 LS Gen IV Build :: 1995 Land Rover RRC SWB SGS714 Defender & Series Truck Registry 5 April 25th, 2016 07:31 PM
RRC 2-Door TDI :: 1989 Land Rover RRC SGS714 Defender & Series Truck Registry 0 November 14th, 2015 09:33 AM
95 RRC LWB White 300tdi :: 95 Land Rover RRC SGS714 Defender & Series Truck Registry 0 November 14th, 2015 09:26 AM
Parting out 1991 RRC SWB & 1993 RRC LWB. Erik@Lucky8 For Sale - Parts 0 November 7th, 2013 10:43 AM
95 RRC goodies (some DI & RRC crossover) RoverDude For Sale - Parts 4 August 24th, 2010 03:19 PM
