95 RRC 3.9 - stumbling at just above idle - Defender Source
Old December 17th, 2014, 10:30 AM
corrumpu
chris b
1995/RRC SWB
My RRC 3.9 has had an idle issue that I have yet to sort out. It comes and goes depending on the rover gods. Recently and in the middle of a nice running drive, it started to stumble when i was giving it just enough gas to move (above idle) Say at a stop sign or light turns green scenario.
If you give it just a bit of gas it is stumbling, surging etc. give it too little and it stalls, romp on it and it recovers immediately and from then on has no issue (until another stop sign/light)
I have worked through an IAM earlier in the summer, relocation of that, a bunk metal bosch relay for the ECU and now this! My kids will barely get in my truck for fear we won't return.
Any ideas?
Rovergauge (i don't have one or have access to one, but would this be useful? should I go down this road )
--chris
Old December 17th, 2014, 10:42 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Idle control valve (aka stepper motor).
Old December 17th, 2014, 11:06 AM
It can be a lot of things. You need to get the manual and go through the troubleshooting procedure.
Old December 17th, 2014, 11:12 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
+1 on stepper… may just need a good cleaning
And your base idle may be out of whack too. There's a big list of things to do before messing with the base idle so get a hold of the manual.
Old December 17th, 2014, 11:15 AM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Very true...Here's a good thread on TPS issues
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old December 17th, 2014, 11:20 AM
corrumpu
chris b
1995/RRC SWB
I have rave and will go down that road. I saw the TPS thread, which is where my rovergauge question was from.
Thanks for the input.
--chris
Old December 17th, 2014, 11:22 AM
Stepper motor really only comes into play on deceleration. It opens to add air to the mixture when your throttle plate is closed so that the engine won't pass out. Once it goes to idle the stepper motor closes the bypass air and doesn't open again until you decelerate, so coming off idle it won't be doing anything.
What you may want to look at is the vacuum advance on the distributor. Opening the throttle should give a whoosh of vacuum to advance the distributor plate. If the hose from the plenum to the diz is bad it may not be advancing properly.
Old December 17th, 2014, 11:24 AM
TPS, Stepper, VSS, injectors, CLT, O2.... Lots of things can can idle issues. Just run individual tests and see if you can find one item not working properly. It does not take much time and you will learn a lot about the system in the process.
Old December 20th, 2014, 06:29 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Obligitory random guess......
Alternator
95, idle
Idle Control Valve (idle stepper motor) fleabus For Sale - Parts 3 June 28th, 2009 12:13 AM
stumbling under load when hot..? revtor Defender Technical Discussions 0 May 5th, 2008 08:57 PM
Rough idle, stumbling, dying.... revtor Defender Technical Discussions 9 January 10th, 2008 04:28 PM
Stumbling during acceleration and load Bozman Defender Technical Discussions 8 June 14th, 2006 08:02 AM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
