'95 LWB SRS Light - Defender Source
Old November 24th, 2008, 10:20 AM
Abrooks's Avatar
Abrooks
Tony Brooks
'95 LWB SRS Light
Good friends are moving to Germany and have asked me to get rid of their LWB for them. Perfect interior, Good exterior save a rusty tailgate and some DS light rust (liftgate is spotless). The only issue I've found on it so far is that the SRS light is flickering/on and the TC and ABs lights are illuminated. We're putting a fresh battery into it tomorrow to see if that solves the issue, but failing that and resetting codes, what other luck have folks had? Also, what's reasonable to ask for the truck?
thx
Old November 24th, 2008, 11:00 AM
2k is a fair price depending on miles and condition otherwise. If it does not take to a new battery and a reset, it is going to cost major $$$ to fix.
Ron
PS send me pics. Mine needs a heater core. evilfij (at] yahoo.com
Old November 24th, 2008, 01:45 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
ABS & TC usually point to a bad hub. They are related, so if you get a fault in one, you will get a fault in both, but it is generally the wheel speed sensor which requires replacing the hub.
SRS is anybody's guess, but I know that the seat airbags cause similar issues on P38s. I don't know if a county even has airbags in the seat, but if it does, that could be your problem.
Old November 24th, 2008, 01:58 PM
Not sure about hubs as most of the time it is usually just the wheel speed sensor and the hub is fine. Still a new sensor is really expensive and used is hit or miss.
SRS, if it is not jsut a low voltage situation) is usually the clock spring in the steering wheel (does the horn still work?) or a fault somewhere in the harness (silly dollars!). No seat airbags in an LWB. They came out in the bosch 1999 and up P38a range rovers.
Ron
Old November 24th, 2008, 02:01 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Can you replace just the sensor? I know at the dealer they always replace the whole hub (on disco II's at least), so I thought you had to.
Ron
Ok, I didn't think they had seat bags, but wasn't sure. The clock spring came to mind as a seemingly likely culprit, but I've never actually seen one go bad.
Old November 24th, 2008, 02:26 PM
DIIs it is integral with the hub, earlier trucks it is seperate. The only things that go wrong with these type of hubs are blown up bearings (lack of servicing, water ingress) or the bolts strip that hold the flange on.
Ron
95, ht, lwb
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
95 LWB for sale in NC Gventure For Sale - Vehicles 11 March 2nd, 2009 11:02 AM
'95 Lwb Abrooks For Sale - Vehicles 20 January 20th, 2009 06:05 PM
95 Lwb F/s Tim Scully For Sale - Vehicles 2 January 16th, 2009 02:14 AM
'95 LWB airbag light Abrooks Defender Technical Discussions 12 September 9th, 2008 09:53 PM
