95 D90 temp sender range - Defender Source
Old April 27th, 2005, 11:42 AM
naeirie's Avatar
naeirie
Nilo Enerio
95 D90 ST #2571
Question 95 D90 temp sender range
Does anyone know the temp sender range is? I know it's in ohms, but not quite sure how to measure it.
Nilo
Old April 27th, 2005, 11:54 AM
This is the ECU one
http://www.rangie.com/files/167_385.jpg
I don't know what it is for the temp gauge. You could always take it out and put it in a pot of water and compare it to a thermometer.
Old April 27th, 2005, 12:16 PM
naeirie's Avatar
naeirie
Nilo Enerio
95 D90 ST #2571
Thanks for the info.
I may need a new sender/gauge. I have changed the thermostat, temp sender, viscous fan, and water pump. The problem is that the gauge will go past the half way mark (never close to the red line) after about 10 mins of driving, and then settles real close to the center line. Once I kill the engine and start ip back up again the gauge reads below the center mark and never goes back up until I kill the engine again.
This has never happened until I had the radiator out for service and the heads worked on and the cam/timing chain & gear replaced (upgraded).
Nilo Enerio
90, 95, d90
VDO Temp Sender (97 D90) nmc Defender Technical Discussions 0 September 10th, 2009 01:01 AM
Temp Sender Location DJ Menasco Defender Technical Discussions 10 August 28th, 2006 01:24 AM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 07:47 AM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
Engine Temp - Normal range mgrgpg Defender Technical Discussions 5 June 10th, 2004 08:47 PM
