'95 D90 ST roll cage issues - help needed - Defender Source
Old November 1st, 2015, 10:30 PM
doscazadores
Vic Stull
none
I removed the torx bolts that join the "B pillar" and the slanted members that run toward the back. On both sides the lower bolt threads were pretty mushed and that can only mean the two interior nuts' threads are garbage as well. Everything's covered with that rubber/plastic "stuff." Any way to replace those nuts? I don't think trying to recut the threads is gonna be worth the effort.
I'm open to any repair or replace option suggestion at this point, cuz I'm stumped.
Thanks for any help.
Old November 1st, 2015, 11:52 PM
NSGINC's Avatar
NSGINC
Nathan Garnand
74 Series 88
Just clean the nut threads with a tap and get new bolts. You will be just fine.
Old November 2nd, 2015, 12:26 AM
doscazadores
Vic Stull
none
OK. I think it's a 1.25 thread, but I'll check. I have a metric tap & die set that I haven't had to use much, but now's one of those times for sure. Thanks
90, 95, cage, d90
NAS Roll A bar roll cage and front under wing supports defenderholty For Sale - Parts 6 August 9th, 2014 05:49 PM
Implications of going from a NAS roll cage to Full Body Cage. Manimal Defender Technical Discussions 19 June 25th, 2013 08:26 PM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Rear Roll Cage needed BKnotts Wanted 1 January 29th, 2007 12:22 PM
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
