95 D90 need help on part problem!!! Please - Defender Source
Old October 21st, 2010, 11:16 PM
Jason78
Jason Lawrence
1995 Defender 90
Question 95 D90 need help on part problem!!! Please
Hello,
I am a new car dealer from nj,I traded in a D90 for a new silverado and decided to keep the vehicle and absolutely love it.The only part I am currently having a problem with is the steel bar that crosses the frame in the rear and connects on the rear upper front of the wheel well. Rovers north recommend that I get a machine shop to make one,but I was wondering if there is a aftermarket part or anyone know of a used one? I have 4 service dept in my dealerships but unfortantly no technician is furmiliar with these vehicles. before I take the route of fabrication if anyone can help me please respond!!
Jason
Ps if someone could help me out I will give you a great deal on a new or used Ford,Chevy,Jeep,Chrysler,or Dodge!!! Or any factory parts needed
Old October 21st, 2010, 11:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
Picture?
Old October 22nd, 2010, 12:59 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
A picture would help. Is it part of the rear tub (body) or part of the roll cage?
Roll Cage --part number is likely ALR5557
Raer Tube - part is likely MUC8949
Suggest you call Britcar or John Craddock -- both in the UK
Old October 22nd, 2010, 01:25 AM
rovertrader's Avatar
rovertrader
Dale
if it is the middle bulkhead removal piece(right behind the front seats), I have a couple of them
Old October 22nd, 2010, 01:40 AM
I think he's talking about the part of the roll-cage that goes under the body.
What is the problem - is it rusted out?
The good news is that should be easy to source from ECR as a replacement part. The other good news is that as a replacement or retrofit part it is made differently than the OEM part. The replacement has a break in the middle to facilitate the install. Then you just sleeve and bolt it.
Lets see some pix of this truck, we can probably help you out with a lot of things, like the oil cooler lines that you probably don't know you need to replace ASAP!
90, 95, d90, part
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
'95 Yellow D90 ST w/ 3 tops dalesmith71 For Sale - Vehicles 10 March 19th, 2004 09:59 AM
Diagnostic Plug on 95 D90 SW? Troys Defender Technical Discussions 5 March 13th, 2004 03:49 PM
