95 D90 Can't start !!!!! - Defender Source
Old July 27th, 2004, 03:12 AM
Vadim
vadim
95 D90
Question 95 D90 Can't start !!!!!
I have 1995 D90.I had light accident.Front end damage.Car use to runs just fine,all body work its done.I try start it today but funny thing happen.It will not start.I mean it start and engine turn,but it die right away.I check for gas ,has gas,spark,everything seems allright,but soon it starts it die .I suspect may be its safety cut off fuel switch somewere( like Ford's has ) ,but I can't find it nowere So I am lost.
Any idea what it could be ?
Old July 27th, 2004, 03:26 AM
XD90's Avatar
XD90
James Morgan
1986 Ex MOD XD90
could be the 12V supply to the fuel pump or more than likely an airlock in the fuel system slacken the bleed screw off the injector pump and then pump the feul lift pump manually till all the air escapes and fuel runs out without bubbles
James
Old July 27th, 2004, 08:07 AM
That would be it! Look behind the fuses, there should be a little black box that looks like a relay with a red button on top. Push the button in to reset it.
Old July 27th, 2004, 01:04 PM
Vadim
vadim
95 D90
Hi Mike .Are this cut off switch for real ? Were this fuse box ? Sorry for stuped quistion?
Thank you
Vadim
vad@zoomtek.com
Old July 27th, 2004, 01:08 PM
On my 95 the button you are talking about is on the driver side (I think) of the firewall
Old July 27th, 2004, 01:31 PM
Vadim
vadim
95 D90
Inside or out side of car ?
Old July 27th, 2004, 01:32 PM
Fuse box next to the T-case shifter. In the pic it is the black round knob next to the red relay.
Old July 27th, 2004, 01:38 PM
Vadim
vadim
95 D90
Thank you very much .Finally I will run this baby today>WOW.
Thank you everybody
Vadim
Old July 27th, 2004, 01:54 PM
I have attached a photo of where the "inertia swith" is on a 95 D-90. I dont think its the same as a 94. Hell it might not even matter now just thought I would post anyways. It's circled in yellow...
Old July 27th, 2004, 02:37 PM
Hey Phillip, can you make the pic a little bigger?
Old July 27th, 2004, 02:47 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Forget about bigger, can you make it a bit dirtier??? hehehehe... just kidding.
John C.
I dont know how, if you click the photo it gets bigger, sorry
Old July 27th, 2004, 03:28 PM
Vadim
vadim
95 D90
Phillip this photo from cut off switch ? From 95 ?
Old July 27th, 2004, 03:42 PM
yeah. the picture is of a 97 but its exactly the same on my 95.
Old July 28th, 2004, 03:52 AM
Vadim
vadim
95 D90
Thank you everybody.I found G-Damn switch)))
90, 95, d90, start
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
D90 won't start dameek Defender Technical Discussions 1 November 11th, 2004 09:00 PM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
