95 D-90 5th gear broken - Defender Source
Old February 18th, 2009, 07:06 PM
DG Rodgers
DG Rodgers
1995 Defender 90
Wondering if someone can help me figure out what just happened to my 5th gear. I have a 5 speed manual transmission. Everything was shifting beautifully until this evening while driving home in 5th gear at about 60-65 mph. I accelerated and just got a rapid engine rev with no gear. I slowed and shifted into 4th. The rest of the way home 1st - 4th gears were fine. I tried 5th once again and it just wasn't there. I have searched high and low but haven't found this problem addressed. Any insights into what happened and where to get any parts I might need would be greatly appreciated. I have a Series III that I work on with no major snags but I just got this D90 recently and I am not so sure. Please help if you can.
Old February 18th, 2009, 07:10 PM
Black_and_Blue's Avatar
Black_and_Blue
Tommy Moore
1994 #1398
Well at least you got home, and other gears are working! I didn't have the same luck - 5th went, so I stayed in fourth, then when I stopped none worked. Needed a new transmission. Someone here with technical expertise will probably be able to help you with official diagnosis ...
Old February 18th, 2009, 07:15 PM
Do you have reverse? It is common for the 5th reverse shaft to sheer.
Old February 18th, 2009, 08:45 PM
DG Rodgers
DG Rodgers
1995 Defender 90
Wow, thanks for the fast replies. This forum is the real deal. I do have reverse. I checked it when I got to the house. 5th makes a lighter steady grinding noise when I ease off the clutch but no grab...if that makes any sense.
Old February 19th, 2009, 10:06 AM
Sounds like it could be a linkage issue as I have never heard of just 5th failing. I would pull the tunnel cover and the lever off and see if it is anything obvious. Roadsiderob here is the transmission expert. He would have better advice.
90, 95, d-90
'95 Defender 90 Soft Top, Con. Green Bozman For Sale - Vehicles 6 August 30th, 2008 06:39 PM
5th Gear Issues bdthornton7 Defender Technical Discussions 0 August 17th, 2008 03:33 PM
5th gear and Reverse sticking anthony Defender Technical Discussions 2 May 22nd, 2007 12:09 AM
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
