95 Classic idle issues since MAR - Defender Source
Old November 11th, 2014, 11:24 PM
UKmtrsp
Chip
95 RR Classic
Looking for a little advice on a 14CUX system. Rode the trails Friday and Saturday with no issues. Cold night into Sunday morning. Started fine as usual Sunday to go for one last trail ride. During warm-up I noticed some variation in the idle...searching a little. Seemed fine though once out on the ride. Drive home to Richmond mostly 70-75 mph no problems. Mostly OK over the past few weeks with just slight idle blips once warmed up...however it has gotten much worse and more frequent over the past 10 days. Symptoms have changed a little though...starts just fine and has good warm-up idle when cold, but starts to struggle to stay running once warm...idle is up and down...sometimes cutting off. Once moving over 35-40 mph the truck seems to run fine until coming to a stop where it begins to stumble. Small hesitations at slow speeds. Seems to pull fine under load and coming off of idle. Haven't noticed any issues with gas mileage.
No CEL
To this point I have cleaned and lubed the IAC motor, replaced the motor with new, replaced the motor with good used from a 91, cleaned the throttle body, cleaned the MAF, disconnected the battery many times to reset the system, checked for vacuum leaks, reset the pickup air gap, checked connectors at the distributor and temp sensor. I intend on checking the connections for the ignition amplifier in the morning...on the 95 its located next to the coil tucked under the upper left radiator bracket. I have a 91 that I can test parts from as well.
Thoughts and suggestions are welcome...
Thanks, Chip
Old November 12th, 2014, 03:57 AM
Swap the water temp sensors over.
Old November 12th, 2014, 08:23 AM
UKmtrsp
Chip
95 RR Classic
Update: Drove my son to school this morning...conditions damp, foggy, about 60deg...RR started and ran like crap immediately...did not want to idle and cut off couple of times while I was getting him in the truck. Once in gear and moving symptoms were less. After warm-up symptoms were even better. Stopped to fill the tank as I was on about 1/8th...noticed no hissing when I began to loosen the filler cap...filled and drove back home 1 mile or so...once home idle searching and low with inconsistent popping missing sound from the exhaust. Will be trying different stuff this morning...ie swapping parts.
Chip
Old November 12th, 2014, 09:04 AM
throwing any codes ? Any rattles in your exhaust ?
Old November 12th, 2014, 10:07 AM
My .02:
You describe classic symptoms of a failing ignition amplifier module. That would be my first suspect, especially since you say the poor running is worse in damp conditions.
Another thing which may or may not be happening, since I can't recall if the 95 has the fitting for the temp sensor in the upper radiator hose, is a coolant leak onto one or more ignition components. I have had (and have now) a leaking coolant temp sender that drips onto the dizzy and into the amplifier. Since I'm so lazy I just have a bunch of paper towel stuffed under it and that keeps the diz dry for now.
Do you have the ball looking vacuum accumulator thing? Those can fail and give you a vacuum leak.
One other tip, replace all the rubber air/vac hoses with silicone hose from McMaster Carr. It won't rot and give you grief.
Old November 12th, 2014, 10:11 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
+1 worth a shot every time
Old November 12th, 2014, 12:35 PM
UKmtrsp
Chip
95 RR Classic
Not familiar with +1...is fuel system conditioner?...can you enlighten me...thanks
Old November 12th, 2014, 12:59 PM
means he agree's with Rocky's post
Old November 12th, 2014, 02:17 PM
UKmtrsp
Chip
95 RR Classic
Thanks Doug...got it...a little slow...immersed in a quandary! Missed you at MAR..did you make it?
After lunch update...swapped coil, MAF, ign module...no improvement...MAF didn't seem compatible as I believe the 95's have gold contacts and a differing resistance.
Drove it to lunch and tried to make further observations...again seems to run well above 1500rpm, about 40mph....anything around 20-30mph will produce a surging...will sometimes shut off when coming to a stop, mainly from higher revs. Idle is low and inconsistent...with some slight popping or missing audible from the exhaust.
No codes or CEL
fuel pump sounds smooth and consistent...although could bad fuel cause/contribute to poor running at lower revs and no issues at speed?
I will be swapping out the temp sensor next.
Chip
Old November 12th, 2014, 02:45 PM
You have an air leak somewhere.
Old November 12th, 2014, 04:12 PM
UKmtrsp
Chip
95 RR Classic
Bill and group,
thats makes some sense to me...vacuum gauge check shows about 16...a little low considering the timing is bumped a little...sprayed a little carb cleaner around...could not find the sweet spot, however it may have swelled the valley gasket some as it seems to be a little smoother...I also bumped the base idle a little to compensate...not looking forward to a valley gasket job, but probably spent more time swapping parts and checking other stuff.
I will get my 91 up and running and see what the vacuum gauge says....apples to oranges, but may be enough of a comparison to confirm leak issue. I will also run as is for the next few days to see if any symptoms change.
I will update once work is done.
Thanks for the help and suggestions,
Chip
Old November 12th, 2014, 07:47 PM
UKmtrsp
Chip
95 RR Classic
Ok, the 91 shows about the same 16 at idle on the vacuum gauge. I am sure that if I backed off the timing and turned the base idle screw back to where it was the 95 would be below 16. Its driveable as it is at the moment, but I do think I have the beginnings of a manifold leak. pinching off the hoses makes no difference. Looks as though I need to schedule sometime to work on my own vehicle. Follow up in a week or so...
Chip
Old November 12th, 2014, 08:01 PM
87 D110 (Ruby)
Tps ?
Old November 12th, 2014, 08:11 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Chip
Hey Chip, go around and just check that the intake bolts are tight---these are notorious for coming loose over time. I have seen some only finger tight before.
Rent my
Old November 12th, 2014, 08:39 PM
UKmtrsp
Chip
95 RR Classic
Jeff,
I was thinking about trying to retorque them in the morning...it might buy me a little time.
Also going up to the DC Happy Hour next Thursday...having a cold one and purchasing a Cat Back exhaust from another Rover enthusiast...Any interest in joining us? Not sure of the location yet.
Chip
Old November 12th, 2014, 10:24 PM
carlosz's Avatar
carlosz
Carlos
Use a scanner or rover gauge to look at the sensors, and scilloscope will help narrow primary ignition issues and do not forget to replace your fuel filter and measure the fuel pressure.
Don't hunt for a ghost, diagnose before repair not he other way around.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old November 12th, 2014, 10:48 PM
UKmtrsp
Chip
95 RR Classic
Carlos,
Thanks, I'm on it. I'm looking into getting a cable for Rovergauge shortly. as for other test equipment, vac gauge, timing light, multimeter, wideband o2 unit....don't have a scope...so sometimes its do your best with what you've got, or what others are willing to lend you in the way of equipment, good advice, or personal experience such as yourself. I appreciate it
Chip
Old November 21st, 2014, 01:57 PM
UKmtrsp
Chip
95 RR Classic
Problem found!
A quick look at the parameters with Charles (Rovergauge) and Jonesy last evening showed that my TPS was way off...reading something like 70% at idle when it should be below 10. A quick unplug and the motor idled right into spec. I am on the hunt for a good used flat 3pin unit and should secure one soon hopefully.
I had a thought in the meantime wouldn't it be possible to elongate the mounting holes a bit and turn it slightly in order to get off the possible bad spot on the potentiometer grid....if thats all thats wrong....just as a temporary fix.....15% would be certainly better than telling the ECU 70%
Chip...On the trail of a TPS
Old November 22nd, 2014, 06:44 PM
was the idle surging at all?
Old November 22nd, 2014, 08:22 PM
UKmtrsp
Chip
95 RR Classic
Yes at times it would surge....maybe 20% of the time....what are you thinking ?
95, classic, idle
Idle Issues: TPS? scolvus.x Defender Technical Discussions 10 August 24th, 2013 03:13 PM
Idle Control Valve (idle stepper motor) fleabus For Sale - Parts 3 June 28th, 2009 12:13 AM
Since there are some MTB. riders here devinchi Misc. Chit-Chat 11 September 29th, 2007 02:00 PM
Since We're Talking Tires? saber6 Misc. Chit-Chat 7 December 3rd, 2005 10:01 PM
Since I am here in the UK..... whitelandy Defender Technical Discussions 35 September 24th, 2004 11:35 AM
