95 Classic idle issues since MAR - Page 2 - Defender Source
Old November 24th, 2014, 08:19 AM
im dealing with a similar issue on my Classic
Old November 24th, 2014, 09:01 AM
UKmtrsp
Chip
95 RR Classic
So this is what I've come to find out at this point and maybe it can help you too.
Several articles and discussions indicate that the role of the TPS is to let the ECU know what position the throttle plate(butterfly) is in at any given moment...as its name suggests. As you increase the opening the ECU changes the injector pulse width to accommodate the engines need for more fuel.
In my case and as I understand it as these potentiometers reach about 100k you are on borrowed time. the contacts(grid) tend to begin to wear out in the spot where it spends the majority of its time...that would be the idle position.
When Charles hooked up the Rovergauge the other night on my truck it showed about 70% in the TPS bar scale at idle. We unplugged the TPS and the idle settled right down to normal revs and was consistent. The normal reading at idle should be somewhere around 5-6%. Since these later TPS units are not adjustable(no elongated holes for mounting) I am game to modify mine a little in an attempt to get it off the bad spot on the grid at idle then let the system relearn the TPS position in an attempt for a temporary fix...wouldn't be doing this if the little bastards weren't so frickin' $$$$. I may have the time to try this out later today, but really want to have an interface with the system when I do it so I can tell whats going on...I now have a Rovergauge cable thanks to Charles and will be reworking a laptop shortly to get it up and running. Thanks again Charles...on the hunt for connectors!
Old November 7th, 2015, 08:21 AM
TTT did the TPS fix your issue?
Old November 8th, 2015, 09:05 AM
UKmtrsp
Chip
95 RR Classic
Yes it did!
95, classic, idle
Idle Issues: TPS? scolvus.x Defender Technical Discussions 10 August 24th, 2013 03:13 PM
Idle Control Valve (idle stepper motor) fleabus For Sale - Parts 3 June 28th, 2009 12:13 AM
Since there are some MTB. riders here devinchi Misc. Chit-Chat 11 September 29th, 2007 02:00 PM
Since We're Talking Tires? saber6 Misc. Chit-Chat 7 December 3rd, 2005 10:01 PM
Since I am here in the UK..... whitelandy Defender Technical Discussions 35 September 24th, 2004 11:35 AM
