'95 classic coil hookup - Defender Source
Old March 29th, 2016, 07:55 AM
tzbmcp
Tyler
110 LHD 3dr
I've looked at wiring diagram from a prior thread and RRC manual, and likely Im missing something, but would anyone be able to take a pic or explain the wiring connections at the coil on my '95 LWB? Four wires connect: 1. all white 2. white with green 3. white with black 4. white with black. Need to know which go to positive and which go to negative terminal on my coil. Looking at the coil both white/blk wires go to the positive terminal, the other two wires go the neg terminal which I think is incorrect. Looks like the all white and one of the white/blk wires come from amplifier module which is mounted adjacent to the coil. Truck is angry and won't start right now but it was previously set up this way (for a long time). Thanks
Old March 29th, 2016, 10:05 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
You have it reversed. Both white w/ black go to the negative side of coil.
Old March 29th, 2016, 10:19 AM
tzbmcp
Tyler
110 LHD 3dr
yep - switched everything around and bam, started right up! thanks
95, classic, coil
200Tdi ignition hookup Jbirdlott Defender Technical Discussions 4 February 15th, 2014 06:07 PM
Preowned Rolex Hookup? javelinadave Misc. Chit-Chat 21 October 5th, 2013 09:49 AM
95 Tach hookup red&yellowrovers Defender Technical Discussions 1 April 2nd, 2012 03:31 AM
New "American Style" Heater hookup tomaco1 Defender Technical Discussions 4 November 18th, 2008 05:32 PM
Heater hookup TDI Guy Defender Technical Discussions 27 April 19th, 2005 03:16 PM
