95 3.9l 10 bolt or 14 bolt head - Defender Source
Old June 24th, 2010, 03:15 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
I am ready to pull the heads and was looking at the workshop manual and it shows a 14 bolt pattern. I can only find 10 bolts on mine. So I am actually not finding the other 4 or is there actually a 10 bolt head on a 3.9l? If so, is there a 10 bolt tightening pattern?
I saw a reference in another thread about this possbility but I just wanted to be sure.
thanks
Bill Lewis
------ Follow up post added June 24th, 2010 03:36 PM ------
Nevermind, I found the 10 bolt pattern in the Rave. I looked at that page several times but finally saw it.
------ Follow up post added June 24th, 2010 04:38 PM ------
But now noticing it says suffix B for the serial number for this pattern, do I have to specifically order the composite gaskets? It says the metal ones are for non-suffix B engines, composite for suffix b. I would assume it matters but I have read lots of threads where people said to get the new composite gaskets without regard for engine serial number.
Bill
Old June 24th, 2010, 10:15 PM
kolvedic's Avatar
kolvedic
Bill Lewis
I'd like to bump as I am trying to get these fI&(UI head bolts off but they won't budge. Wondering if anyone has had the same problem? Or maybe how to get them loose?
Bill
Old June 24th, 2010, 10:25 PM
Grover's Avatar
Grover
Thumbs up
Breaker bar plus a 2 foot cheater bar. It took everything I had, but I got 'em loose. The rears are in a tight space, be very carefull not to strip the bolt theads. Good luck.
Old June 24th, 2010, 10:30 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Rock on thanks! I had started with the cheater bar but was kind of afraid to go too hard. I think I need more beer and bigger friends.
Bill
Old June 24th, 2010, 11:48 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Make sure you have enough beer for bolt 8 on the left head. It's more than a one beer bolt!
Old June 25th, 2010, 12:35 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Thanks guys. I got the left one broke loose but a socket paid the price. I guess it is nice to know the socket split before it did anything to the bolt.
Bill
Old June 25th, 2010, 02:53 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Both my 3.9's had 10 bolts.
I used a 1/2" drive 6pt impact socket, 18" breaker bar and hi-lift jack handle.
Most came easy enough, but a few took a lot.
Also make sure you clean any gunk away from around the bolt heads so the socket seats completely.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 25th, 2010, 02:55 PM
If you had metal gaskets, to upgrade to composite, you should either fit a set of later heads or have yours skimmed. A lot of people just put on composite gaskets without doing either.
Old June 25th, 2010, 03:10 PM
kolvedic's Avatar
kolvedic
Bill Lewis
ok. I was just confused that mine has the 10-bolt which I am assuming makes it a suffix B engine. That engine is supposed to have composite gaskets and has a different set of torque specs (15 ft/lbs + 90 deg. + 90 deg) instead of 60 Nm/90 Nm. anyone know which torque specs need to be used?
I have also been over the inspection list in the cylinder head and valve sections. Anyone have anything else to look out for?
thanks for all the help guys,
Bill
So I am going to ask but I think I know the answer, should I have the heads rebuilt while they are off?
Bill
Old June 25th, 2010, 07:45 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Ok, any recommendations on getting the two right-hand lower rear bolts out of the exhaust?
Bill
Old June 25th, 2010, 08:19 PM
Frank84
Frank Battersby
95 D90
If you are talking about the exhaust manifold to head bolts just leave them there and remove the head and manifold as an assembly since you're taking the head off anyway.
'95 Soft Top
'89 Classic Tdi
Old June 25th, 2010, 09:27 PM
Torque specs (really the bolt that you use) coinside with the type of gasket.
Old June 25th, 2010, 11:40 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Thanks for all the help guys. I got everything off and headed to the machine shop tomorrow.
Bill
Head Bolt choices Antichrist Defender Technical Discussions 25 May 1st, 2010 07:31 PM
Head Bolt with Alternator Stud, Is It Needed? Grover Defender Technical Discussions 6 October 28th, 2008 12:33 PM
Head bolt torque Bowtracer Defender Technical Discussions 1 September 14th, 2005 11:22 AM
