94 with AC- how to get to the inertia switch ? - Defender Source
Old September 8th, 2006, 11:27 AM
94SW,4.6HSE,93LWB,83 110
I have the 94 rollover restoration project from ebay well underway. Trying to get the truck finished for the MAR as a station wagon. The truck runs and drives but the fuel pump has a hot wire running to it. The inertia switch or the fuel pump relay (same general location) need my attention. How do I access them without completely removing the ac system inside the truck ?
Old September 8th, 2006, 12:36 PM
Abrooks's Avatar
Abrooks
Tony Brooks
The inertia switch is actually on the right hand side of the fuse box on the bulkhead -- no need to eff with the AC. Black box with a plunger on top. If the plunger is up and you can see a red stripe, it's tripped.
Old September 8th, 2006, 02:58 PM
fuel pump relay
on my 94 its actaully on the left of the fuse box behind a bracket. Its not popped up so it must be the fule pump relay which according to the manual is behind the right side toe panel. Which of the three relays is the fuel pump.
Old September 8th, 2006, 03:11 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Its a metal cased relay (there are 2). Its the one with a white with a purple stripe wire going into it.
Email:
ac, switch
94 AC Dash Fascia budz Wanted 2 May 20th, 2009 07:33 PM
What is the Inertia Switch for? Mark M Defender Technical Discussions 9 December 21st, 2004 11:06 AM
94 Square Tail lights switch to 95/97 ?? mfreeman17 Defender Technical Discussions 12 May 17th, 2004 04:58 PM
