'94 Tansfer Case Replacement - Defender Source
Old December 29th, 2008, 06:57 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
I was just wandering if there was a transfer case that you could get that wouldn't freekin' leak?!??! My wife is getting pissed about the driveway having oil all over it?
Old December 29th, 2008, 07:10 PM
An empty one... Sorry, couldn't resist. You could pull it and replace the seals, that should cure it for a while.
Old December 29th, 2008, 07:20 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
yea... done that a couple of times, I am looking for a more permanent solution... Seems that even with the seal done, and great stuff the O rings, only last like 2 years tops...
Old December 29th, 2008, 10:34 PM
Where is it leaking? If it keeps leaking from the output, you probably have bad bearings or the seal has worn into the shaft.
Old December 30th, 2008, 12:03 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Have Rob rebuild it. no leaks then..
Legend in My Own Mind.
Old December 30th, 2008, 10:12 PM
Montgo1715
D Montgomery
1994 AA
Waxoyl your driveway and hose it off
Now that is a big trunk. It holds a tuba, a suitcase, a dead dog, and a garment bag almost perfectly.
ac
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
