'94 taillights and Daimond Plating - Defender Source
Old January 13th, 2004, 11:42 PM
proulx70's Avatar
proulx70
Paul S.
1997 NAS BRG Soft-Top
Can the taillights on a '94 be swapped for the newer round style or is there a massive hole in the rear body since the '94 lights are all in one piece?
Also, if you find the perfect vehicle (price/mileage/condition, etc.) but there's diamond plating on the front fenders, can they be removed and holes patched, or will it just never look the same?
Thanks!
Paul
Old January 13th, 2004, 11:48 PM
I think with the plating depending on circumstance there could be some fading of the paint around the area I am not 100% since I have not had any first hand experience with it. Maybe just keep the plating?
Old January 14th, 2004, 12:21 AM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
I just installed the checkerplate on my wing tops and they required 5 holes be drilled into the wing top. So I don't know how good it would look if you took them off.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old January 14th, 2004, 12:35 AM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
"Can the taillights on a '94 be swapped for the newer round style or is there a massive hole in the rear body..."
You could probably just fab up a backing plate to cover any holes left, but it's my opinion that the older style are better units anyway.
The newer style are notorious for filling with water and crud and shorting the bulbs out. It's even possible for the short to be so bad that the ECU can be damaged. Here's more on that:
http://www.expeditionexchange.com/D90brakelite/
There is an upgraded socket available with a bit more protection but I think you should still drill the weep holes just in case.
Also, if... there's diamond plating on the front fenders, can they be removed and holes patched?...
It'd most likely be easier and cheaper to just replace the entire fenders. The wingtop protectors are installed by drilling into the body. Again, in my opinion I believe it's better to leave them on. The aluminum wingtops are very thin and susceptible to dents with very little pressure as compared to the steel fenders of most vehicles. If you own your D90 long enough you'll probably end up with tiny dents in the wingtops anyway. Even if you're very careful, there are times when others may be accessing your engine bay and unknowingly leave a dent by leaning on the wing tops. With the protectors in place you can stand on the wings.
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old January 14th, 2004, 01:51 AM
scot's Avatar
scot
Scot Yount
95 Coniston Green D-90 SW
I like the older tail lights much better....
Wherever I go...there I am.
Old January 14th, 2004, 02:30 AM
proulx70's Avatar
proulx70
Paul S.
You guys rock!
Thanks.
Paul
ht, lights
