94 st fuel pump relay - Defender Source
Old February 5th, 2012, 02:34 PM
discoinjapan's Avatar
discoinjapan
Michael Bruzga
93 D1/ 94 D90 ST/96 D1
OK, been searching on the boards and on the truck.. Still can not seem to find the relay!! Its a 94 D-90 st. I have 2 yellow relays under the fuses inside on the firewall, Im looking for the silver bosch relay but cant find one anywhere. Would someone please tell me where? A picture would be perfect!!!
Thank you,
Old February 5th, 2012, 03:43 PM
If you have AC it is on top of the AC in the passenger side footwell. You can see it near the ECU. Even my fat hand could get to it, but it was TIGHT. IIRC I pulled it off its mount and then pulled the relays out of the mounts. There may be a small trim panel there, but my 1994 did not have it so I don't know.
Old February 5th, 2012, 03:54 PM
discoinjapan
Michael Bruzga
I do have AC, Thank you sir!! I will check now!
------ Follow up post added February 5th, 2012 03:59 PM ------
This is driving me nuts... Looked above the ecu... nothing.. Do I need to remove the a/c condenser and blower?
Old February 5th, 2012, 04:26 PM
discoinjapan
Michael Bruzga
GOT IT!!! had to pull off the AC.... someone has been in there before!!! Thank you.. truck is running now!
fuel, relay
Fuel pump relay 95 D90SW alaskajgg Defender Technical Discussions 32 September 18th, 2006 10:26 AM
