94 st clutch - Defender Source
Old December 27th, 2010, 07:18 PM
discoinjapan's Avatar
discoinjapan
Michael Bruzga
93 D1/ 94 D90 ST/96 D1
94 st clutch
OK, the truck has been running fine except for the clutch is now really soft and it almost falls to the floor. Cecked the fluid and it was low, filled it up but still not much of a clutch and I can barely shift. Can anyone please let me know what to trouble shoot or rplace? I was to head back to VA from PA tomorrow morning but...
Any help?
Old December 27th, 2010, 07:29 PM
bjf's Avatar
bjf
barry f
94 ST #395
Slave or master cylinder seal on the clutch probably went. Before you know it, you will push the pedal down and it won't come back. Just replace the master and slave cylinders.
Old December 27th, 2010, 07:33 PM
discoinjapan
Michael Bruzga
Thanks Barry!
Old December 27th, 2010, 08:21 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Any help?
Is it peeing on your foot? You might not need both yet. I did a clutch job a year ago and bought the master and slave at the same time. The slave is still in a box on a shelf in the shop. You will have no problem driving it wherever you want as long as you keep the fluid full. Drove mine that way for three months.
And hay
And I love you too
Old December 27th, 2010, 10:22 PM
Look for the leak and you will know if it's the master or slave. Even if it fails you can drive without a clutch so I'd get home before trying to do anything about it. Good luck.
charles
Old December 27th, 2010, 11:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
It's usually one or the other not both but f you are in there, I would do both.
Old December 28th, 2010, 11:22 AM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Sometimes the slave will leak into the bell housing and leave no trace of a leak. If you are do'n one....do them both hence the new found pressure of the new part will almost cause the counterpart to go out soon. Look for leaks and if you don't find any then bleed the snot out of it and see if you get pedal back. When these things sit for awhile they seem to loose pressure and all it needs is a bleeding.
Old December 28th, 2010, 06:32 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Naaa. I probably will make it 5 more years without doing the other one.
And hay
And I love you too
Old December 28th, 2010, 07:42 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
If your do'n it yourself then sure. The clients I deal with don't like comebacks and neither do I.
Old December 28th, 2010, 08:38 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I'm envious. You get to work on cool stuff. I keep a fleet of old F150s running all the time. I don't enjoy it much. I didn't realize there were people that own these things that don't know anything about cars and don't work on them. I'm in the the wrong business.
And hay
And I love you too
Old December 29th, 2010, 11:43 AM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Damn right!!!
Old December 31st, 2010, 07:23 AM
discoinjapan
Michael Bruzga
Thanks for all the info guys. Havent had access to a computer... I had fluid leaking down the cluth pedal so I did replace the master then tried to bleed it but nothing would come out of the bleeder so I replaced the slave as well and all seems to be good now but its difficult getting into gear and sometimes out. I suppose I need to adjust the nuts on the master....
Old December 31st, 2010, 05:01 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Bench bleed first and try to set things like the old one ahead of time. You will get it. I knew someone was peeing on your foot.
And hay
And I love you too
Old January 1st, 2011, 10:07 AM
discoinjapan
Michael Bruzga
Yep, The wife doesnt want me wearing the boots anymore because they are so stained now... they are my favorite cotton timberlands. All seems to be good now. adjusted the master a little yesterday and I have a little more clutch to work with and is shifting fine
clutch
Fitting a fiberglass hardtop on my 94 st Lindy Defender Technical Discussions 2 November 21st, 2008 04:07 PM
Land Rover Greenville SC 94 ST rover4x4 The Flea Market 2 August 12th, 2008 08:23 PM
Which door for my 94 ST? texmoto Defender Technical Discussions 8 May 21st, 2008 07:45 PM
Thinking of buying a '94 ST Defender Mark M Defender Technical Discussions 19 June 7th, 2004 10:20 AM
car cover for 94 ST with brush bar/no winch Marc Weinstein Wanted 2 April 12th, 2004 11:20 AM
