94 Square Tail lights switch to 95/97 ?? - Defender Source
Old May 13th, 2004, 11:30 AM
mfreeman17
Mark Freeman
94 D90
Has anyone switched out the square tail lights on a 94 to use the circular 95/97 tail lights? Do the 95/97's fit without modification? Thanks for your help in advance.
Old May 13th, 2004, 12:02 PM
jstrong98's Avatar
jstrong98
Jon Strong
I have a 94, just wondering , why do you want to switch them ?
Mine seem fairly simple to service/remove.
JS
Old May 13th, 2004, 12:08 PM
mfreeman17
Mark Freeman
94 D90
My buddy has a 97 and I just like the look of the circular lights better.
Old May 13th, 2004, 12:18 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I switched them on my 110 (I also like the look of the round lights better). I had to drill large holes for the plastic housing to fit through, and then also some small mounting holes. The lights have a connector so I also had to buy a pigtail that had the mating connector. I can find the PN if you need info. Also, on the 110, the roll cage is runs right behind where the two outside lights go. So I had to remove that section, and I still need to modify it to get it back in. Hopefully you won't have to do that on a 90.
Old May 13th, 2004, 12:56 PM
mfreeman17
Mark Freeman
94 D90
Ryan - thank you for the information. Do you have handy the PN info?
Old May 13th, 2004, 01:57 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Not sure what you've gathered up yet, but here's what I used:
(2) Stop Tailight Assemblys PN AMR6526
(2) Indicator Tailight Assemblies PN AMR6527
(1) Reverse Tailight Assembly PN AMR6528
(5) Tailight Plinths PN AMR3850
(3) Connector Repair Kits, 2-pin, PN LRN-00-0005
(2) Connector Repair Kits, 3-pin, PN LRN-00-0006
I bought this all through Rovers North. There are military lights that are better quality than these, but much more expensve.
Old May 13th, 2004, 03:53 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
You might try Rovers Down South (www.roversdownsouth.com) for possibly better prices than Rovers North, I've gotten a replacement AMR6526 from RDS in the past.
Originally Posted by Mike Hippert
I could run circles around Dave Souzas 90
Old May 13th, 2004, 09:05 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
I was thinking of changing out my 94 square taillights as well (don't like the look much). Can anyone identify these lights?
I deleted your Double post. Mike
Old May 14th, 2004, 02:10 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Not sure if I'm remembering correctly, but I think those were made by Gulf Coast Rovers. But I think they were too expensive to make so they're not selling them. You might check with them anyway: http://www.gulfcoastrovers.com/
Old May 14th, 2004, 04:28 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
They are LED lights, and Ryan is right they are expensive to make. If I remember correctly it cost them about $1000+ for the rear, front, plus some wiring so they blink right.
World traveler
Old May 15th, 2004, 10:23 PM
LED lights have been advertised in the british LR mags that replace the big round lights. They were 20ukp each or so. I have seen in the US the oval fronts on a 94 in LED.
Personally I like the 94 style (I bought Ryan's old ones for my other truck). The 95-97 lights corrode.
Ron
Old May 16th, 2004, 07:43 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
Thanks, guys. Unfortunately, I don't have $1,000 in the budget for lights right now (at least not for taillights). They'll have to go on the long-term list.....
Old May 17th, 2004, 04:58 PM
Shane@EVS
Roverhybrids
I'll second the problem with interference with the inner rollcage when trying to retrofit the newer round lights to a 94.
Only I was actually using a 97 tub so the holes were already there for the lights; but they(all) wouldn't fit due to the rollcage supports. I stuck with the 94 style lights.
95, 97, ht, lights, switch, tail lights
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Can I use a Dome light switch for hella lights tebby Defender Technical Discussions 4 September 5th, 2009 11:12 AM
'94 tail lights on newer style rear body panel? Green Blood Defender Technical Discussions 5 March 29th, 2009 11:20 PM
Square Red Tail Light Lens for 94 D90 bd90 Wanted 0 May 8th, 2006 09:25 PM
