94 Radio antenna part # - Defender Source
Old August 22nd, 2004, 12:33 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
My antenna fell off yesterday while wheeling. Anyone know the part number for it? Tried RN but can't access there search function.
Jimmy Buffett
Old August 22nd, 2004, 01:22 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
AMR3137 up to RA939980
AMR3739 from RA939981, up to SA955971
AMR3976 from SA955972
Insert pithy quote here.
Old August 22nd, 2004, 01:47 PM
flippedrover
Tyler
'94 D-90
Jimmy Buffett
Old August 22nd, 2004, 05:38 PM
I bought one at the auto parts store, $10, and it works better then the old one, it also collapses down so it does not get beat up as much on the trail. I donít know which one I bought, but I just pulled out the old base, brought it down to the store, and got one that matched up good.
Old August 22nd, 2004, 06:04 PM
flippedrover
Tyler
'94 D-90
hmm...sounds like a lower cost idea. I'm willing to bet that the factory antenna is a couple of hundered bucks.
Jimmy Buffett
Old August 23rd, 2004, 08:49 AM
While I was in there I also replaced the cable between the antenna and the radio, as the PO had spliced together the original cable in a couple places.
part, radio
1997 Radio Antenna Removal ronward Defender Technical Discussions 12 August 8th, 2007 08:21 PM
Shark fin radio antenna paulb Defender Technical Discussions 10 February 21st, 2005 11:24 PM
satellite radio antenna install nykx Defender Technical Discussions 8 November 29th, 2004 10:49 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
