94 oil pressure - Defender Source
Old May 3rd, 2016, 10:34 AM
patryk
patryk
none
94 oil pressure
hi im new to this!
working on 94 defender oil pump
came in with engine noise and oil light on, tried primeing the pump but no luck so i started taking the oil filter housing apart to look and see whats going on , just broke one of the bolts on the oil filter housing.
is 1994 defender same as 1995?
looks like i have to remove the front cover and try fixing that bolt or replace it, is this possible?
Old May 3rd, 2016, 10:56 AM
The way to prime the system is to remove the distributor and use a drill to spin the distributor drive gear. The starter usually doesn't spin the engine fast enough to prime the system even if the oil pump gears are packed with vaseline. Welcome to working on rover V8's/1962 technology.
Old May 3rd, 2016, 04:34 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Is that just remove the cap and rotor and attach the drill (somehow) to the rotor location or pull the whole distributor out and go from there?
Old May 3rd, 2016, 04:58 PM
remove the distributor. Its held in by a single nut and clamp.
http://forums.lr4x4.com/index.php?showtopic=8386
Old May 3rd, 2016, 05:52 PM
remove the distributor. Its held in by a single nut and clamp. http://forums.lr4x4.com/index.php?showtopic=8386
Mark it first accurately or you'll need a timing light to position it properly.
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
Oil pressure gage rover4x4 Defender Technical Discussions 4 November 30th, 2004 09:44 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
