94 NAS90 Fuel Pump - Defender Source
Old June 3rd, 2013, 10:44 AM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
94 NAS90 Fuel Pump
Trying to source a fuel pump and only found them at RN ($359) and AB ($289). Checked the other usuals - RDS, Safari with no luck. Anybody have any other suggestions?
Do, or do not, there is no try!
Old June 3rd, 2013, 10:49 AM
someone rebuilt one recently ...
Old June 3rd, 2013, 11:50 AM
wantone
Rick Thompson
94 ST #1222
yes, go to napa and get just the pump, minus the sending unit etc., and a new strainer for about $60 total. pull out the pump/sending unit, pull out old pump, splice in new wires with crimp connectors and done. i forget the part no. but if you do a search it is on here, that is where i got the part no. the actual pump part in these are the same in a number of vehicles btw, so simply searching napa's etc. site for a pump will not give you just the pump but the whole sending unit if memory serves me correctly
Old June 4th, 2013, 09:50 AM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
Found this part # from NAPA, P74006. Based on the threads it looks like every person encountered different obstacles when replacing with aftermarket. Maybe going costly OEM is better to keep things clean and simple.
fuel
