'94 NAS D90 radio wiring diagram? - Defender Source
Old June 11th, 2010, 10:21 AM
PTSchram
P. T. Schram
Down to only six!
Gentlemen:
I am needing to install a radio in a '94 D90. The original radio is AWOL (long story, someday I'll share it).
The owner wants a close approximation of the original and I have a working unit from a '95 Disco.
I need the pinouts for the original '94 radio as it is not the same as for the Disco.
None of the circuit diagrams I have show the '94.
TIA
Cheers,
PT
(yes, I searched!)
pt@btlrovers.com
260-804-0458
Wrench to wheel, wheel to wrench
Old June 11th, 2010, 10:50 AM
ECR has a factory 1994 radio for $100. The DI radio is not similar to the 1994 radio. The wiring is the same as a pioneer aftermarket radio, because well, that is what it was.
Old June 11th, 2010, 12:23 PM
PTSchram
P. T. Schram
Down to only six!
Thank you Ron for that insightful post that was probably accurate, but of no use whatsoever to me.
At this point, I'm merely trying to install something that looks like a Land Rover radio. What are the differences between the two that would preclude it being used in a '94 Defender?
Old June 11th, 2010, 02:03 PM
PT,
My point was that if you search for a pioneer pin out w/colors, it is the same as the 1994 D90. I thought that would be helpful.
Ron
Old June 11th, 2010, 02:21 PM
Frank84
Frank Battersby
95 D90
I have the '94 diagram at home - I'll get it and post it tonight. A '94's wiring is real simple since it didn't have an amp.
I need the '95 diagram myself and that is the only one I don't have - anyone have one? I bought one of the used radios from ECR and then realized I also need the connectors from the harness to the radio and amp...anyone?
'95 Soft Top
'89 Classic Tdi
Old June 11th, 2010, 02:46 PM
PTSchram
P. T. Schram
Down to only six!
ThanX! I need the pin out from the radio to the speakers. I believe it's the center connector.
As I was under the impression that the inputs to the amp on the '95 were speaker level, I had expected to be able to swap it directly. Let's hope that impression is correct (as I scurry off to hook a speaker up directly!).
The connectors are available from among other places, DandBSales.com
Old June 11th, 2010, 04:47 PM
Frank84
Frank Battersby
95 D90
PT -
I realized the diagrams don't show the actual pin locations in the connectors. I attached what I have so hopefully that will be of some help. I guess you may already have the wiring info though.
Frank
Name:	1993 D110 and 1994 D90 radio harness.JPG
ID:	28492   Click image for larger version
Name:	1994 D90 factory radio wiring diagram.JPG
Name:	1994 D90 radio wiring from internet.JPG
'95 Soft Top
'89 Classic Tdi
Old June 11th, 2010, 05:44 PM
GYM's Avatar
GYM
Gary
97 SW
Roverville Radio? I've bought stock harness connectors from him a couple of times.
Old June 11th, 2010, 07:08 PM
PTSchram
P. T. Schram
Down to only six!
PT -
Frank
I've got that.
The D90 uses the same connectors as the Disco radio, but the connector the Disco uses for the speakers isn't there in the D90.
Old June 12th, 2010, 09:25 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
95 Diagram anyone?
Legend in My Own Mind.
Old June 12th, 2010, 09:32 AM
PTSchram
P. T. Schram
Down to only six!
Originally Posted by TDI Guy View Post
95 Diagram anyone?
The '95 uses a different head unit.
Old June 14th, 2010, 07:54 PM
PTSchram
P. T. Schram
Down to only six!
Well, that didn't work out that well. The '95 Disco head unit apparently doesn't have speaker level outputs.
Old June 14th, 2010, 08:10 PM
Call Holly at ECR, pay the $100 and be done with it. It will be plug and play.
Old June 14th, 2010, 11:53 PM
Sorry PT. I have a 1995 D90 amp if that helps. Actually, I think I have two of them.
Old July 19th, 2013, 04:27 PM
Frank
Thanks, Frank for the diagram. I was having trouble finding the wiring color codes.
So from Frank's pic, it looks like:
For 1994 Defender Radio Wiring
Battery + (always hot) = purple
Ignition switched + = orange with white stripe
Ground = solid black
Light switched + = red with black stripe
I can only assume that the difference for 1995 wiring for the radio is that the Ignition Switched + is White with the Orange stripe, instead of Orange with a White stripe. I was replacing my antenna before July 4, and when I went to take the radio out, two of the connections came undone and CROSSED - the 5A fuse blew, I reconnected as I thought I should (pretty sure it was as per what I wrote above), replaced the fuse, and still nothing. The radio itself it fused with a little 10 fuse, which I visually inspected and appeared to be fine (but will be getting replaced since that's the next cheapest step before replacing the radio). Since I'm in there I want to clean everything up and I'm just trying to make sure I have everything connected properly so that I can rule out everything but the radio itself.
Old July 20th, 2013, 11:15 AM
Frank84
Frank Battersby
95 D90
Have any luck with the wiring? '95 is different than '94 in some areas. I went through all the radio wiring diagrams a few years ago for my '95 and I'm a bit rusty but if you need help still let me know and I can refresh myself and figure it out for you.
'95 Soft Top
'89 Classic Tdi
Old July 20th, 2013, 11:27 AM
Too damn hot to tackle. I meant to get out there early this AM, but it didn't happen. I pulled this out of the stock radio I've been hoarding, so at least I know I'm on the right track. What is the yellow wire though?
Old July 21st, 2013, 07:41 PM
Darn. Still no luck. I had about 20 minutes between getting back from vacation, and having to get back to the apt for dinner tonight, and I connected my radio- Pioneer DEH P5200-HD per their diagram:
-Pioneer yellow (constant 12V) to Defender purple (always hot).
-Pioneer red (ignition) to Defender White with Orange stripe.
-Pioneer black (ground) to Defender black.
The local store was closed, so I'll pick up some additional fuses this week (plus the special 10A fuse for the radio itself) and then check for continuity once again to all of the connections I just re-connected if that doesn't work.
ID:	76208   Click image for larger version
90, d90, nas, radio, wiring
'97 Nas D90 Sw Le #008/300 Classic Rover For Sale - Vehicles 19 November 28th, 2013 08:53 AM
Is this the right fan clutch for a 94 D90 NAS? EnduroPro Defender Technical Discussions 3 May 29th, 2010 03:58 PM
Rear Bench for '94 NAS D90 94Def90 Wanted 1 January 21st, 2009 08:06 AM
1995 D90 NAS Frame, 3.9L V8 & Radiator for sale Barnett Childress For Sale - Parts 10 June 22nd, 2005 07:38 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
