94 NAS D90 Overheating - Defender Source
Old September 11th, 2016, 02:58 PM
vir2uosbze's Avatar
vir2uosbze
MARLON
1994 D-90 #560 Portofina Red
About 3 years ago I replaced the radiator with a new one from Rovers North, a new fan clutch, a new thermostat, and a new water pump. Couple months ago (May) I was driving on the interstate and the water pump decided to quit. From that I replaced the water pump again and everything ran perfectly fine. Until now in August I noticed the temperature gauge on the dash started reading hot whenever I'm in traffic only. Thought the fan clutch was going bad and replaced that again. The temperature in Virginia Beach was reading in the high 90's to 104 degrees but still in the past D 90 ran fine. Now it still reads 90% hot and I'm wondering if the new fan clutch I ordered have a defect! I will call Rovers North tomorrow and see what they think. Am I missing something here or have anyone experienced this?
Old September 11th, 2016, 03:08 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Buy a genuine fan clutch... I have seen more bad prolines out of the box then good ones!
Old September 11th, 2016, 03:16 PM
Agree.
Old September 11th, 2016, 04:48 PM
vir2uosbze's Avatar
vir2uosbze
MARLON
Thanks guys, I will return this one to Rovers North and try the one from Atlantic British.
Old September 11th, 2016, 05:04 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
hmm, the AB one might not be genuine. I would definitely ask.
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Also, use an ir thermometer on your rop hose and see if the temp is correct...
Old September 11th, 2016, 10:51 PM
Check your system pressurizes.
Old September 12th, 2016, 04:26 AM
Or use the GM version!
Old September 12th, 2016, 07:22 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
AB would be selling the same one, I would definitely test it, I've seen enough of them fail. We've since switched suppliers to the OE fan clutch, no failures since; but the price has increased accordingly. Or buy Genuine
Please Help...Cant use my D90 off road due to overheating... Cmikefly Defender Technical Discussions 26 July 13th, 2010 03:23 PM
110 tried almost everything and it is still overheating.need some advice draaronr Defender Technical Discussions 21 November 17th, 2004 07:25 AM
Overheating Question Troys Defender Technical Discussions 8 August 11th, 2004 11:04 PM
overheating issue--viscous fan Davis Defender Technical Discussions 5 August 4th, 2004 12:11 PM
overheating- what should i check? MiniGuy Defender Technical Discussions 13 November 21st, 2003 08:13 AM
