94 Nas d90 200 tdi swap - Defender Source
Old February 27th, 2016, 02:24 PM
slatelacy
Slate Lacy
94 ST
Hey guys. I'm just trying to get an idea of what I am looking at. How big of a job is swapping a 200/300tdi into a NAS truck?
Old February 27th, 2016, 02:39 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
don't do it you will likely spend $15000 on the conversion and the truck will be depreciated .... buy a ROW already done....
good luck with your search
Old February 27th, 2016, 02:52 PM
slatelacy
Slate Lacy
94 ST
That's what I figured!
Old February 27th, 2016, 11:48 PM
Grover's Avatar
Grover
Why do you want to swap?
Old February 28th, 2016, 03:21 PM
Chip's Avatar
Chip
Andrew
I agree go for a ROW that already has a Tdi. For NAS I think there are better options that would increase both fuel efficiency and performance, like an LS or BMW I6. Ford sells a turbo 4-cyl EcoBoost crate engine that would probably be pretty rad. I'm pretty sure it'd hook up to an MT82.
Old February 28th, 2016, 08:13 PM
slatelacy
Slate Lacy
94 ST
Thanks for all the info. My truck has a 4.6 with about 10k miles on it and I just can't ever get it to run right. I'm having some kind of ecu/electrical/sensor problems. No one seems to be able to figure it out and I'm getting tired of messing with it.
Old February 28th, 2016, 08:26 PM
Grover's Avatar
Grover
Who performed the swap? Was it a new engine or a rebuild?
Old February 28th, 2016, 08:44 PM
slatelacy
Slate Lacy
94 ST
West coast Rover. I bought it from a guy after the swap. Motor had less than 1000 miles when I got it. It was a new block I believe. It ran fine for a couple of years, but gradually started to act up. Constantly throwing fault code 44. I've changed out damn near ever sensor. No change.
Old February 28th, 2016, 08:55 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
find Jimmy on here he can probably help you.
Old February 28th, 2016, 08:59 PM
Code 44 is the o2 sensor on drivers side..
A loose o2 or damaged will cause that..along with rough running, stalling and check engine lights.
If the o2 is damaged at all replace it.
Also corroded wires/cap/ and other causes can do that as well..
Do you know how to check all the codes? They show in series..
Search cel 45 here..
Going diesel will cost you $15k.. A 4.6 is an even upgrade
95' D90 - daily driver..
Old February 28th, 2016, 09:35 PM
slatelacy
Slate Lacy
94 ST
Also worth mentioning: About a year ago, something started draining the battery, as in a few hours if left parked. Replaced alternator, disconnected radio, checked for interior lights/checked ignition switch. Nothing fixed this. I finally ended up installing a battery cutoff. This happened after being in my garage over the winter. My thinking is, that mice may have chewed a wire or wires, but I have checked everything that I can get to and found nothing.
Old February 29th, 2016, 01:20 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Out of curiosity...
Did you go through every single fuse and connected an amperage meter on the panel with key out of the ignition?
By process of elimination you ought to find a circuit with a sizable amperage flow...
Old February 29th, 2016, 01:26 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Follow the wiring from the sensors; the swap could've had a bad splice or a maybe the wiring melted on the exhaust.
Old February 29th, 2016, 06:58 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
This may be obvious but worth a second mention Imo. The difference in a Tdi's abilities is significant. You should try to drive and get to know well the abilities of a TDI before making a swap. They're both great (tdi's and the 4.6) but very different.
Old February 29th, 2016, 06:42 PM
slatelacy
Slate Lacy
94 ST
I feel like I might need to start a new thread, since I am now discussing the reason for the swap. But heres an update anyway. I cleared all of the codes and just like I am seeing on other threads, truck runs fine for 10-15 min and the light comes on. This time it shows code 45. Funky idle at stop signs (sometimes almost dies), really bad gas milage, I can really smell the exhaust. O2 sensors? I replaced them when this first started happening, but nothing changed. I just ordered new o2 sensors, a tune up kit(plugs, dis cap, wires) and a new ignition/amplifier module. Im out of ideas after this!
Old February 29th, 2016, 06:51 PM
Make sure your current o2's don't look like this
Just realized your close ish too...
Uncle Doug, and a few good shops are close to you.
Pm me and I'll give you my phone number.. Cel's suck but normally have a definitive cause...
Old February 29th, 2016, 06:56 PM
slatelacy
Slate Lacy
94 ST
They looked good to me. Something else that I read pointed to the sensors not getting power if you see both codes. Both codes were present when I cleared out the codes, but just 45 appeared during this last light.
Old February 29th, 2016, 07:00 PM
Check for corrosion on the cap wires.. Pull them from the cap one by one and if it's green in any of them replace the wires and cap.
The right side (pass) o2 can be hit by the driveshaft (it's at a bad angle)..
Denting it can kill it,
Also make sure it's 100% seated at the plug in the engine bay..
I've had about everything happen with cel 45..
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
Used Proline 200 TDI Radiator & 200 tdi intercooler mgreenspan For Sale - Parts 4 April 8th, 2014 03:38 PM
1994 NAS D90 Tdi auto swap Broncoduecer Truck Build-up's & Restores 14 January 25th, 2014 04:47 PM
300 tdi engine cover on a 200 tdi? jayz Defender Technical Discussions 3 July 28th, 2011 05:27 AM
200 TDI vs. 300 TDI? Brenter For Sale - Vehicles 4 September 1st, 2009 09:59 AM
