'94 LED options? Square? - Defender Source
Old June 13th, 2015, 12:55 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hi all. I'm very interested in doing an LED conversion on my 1994 NAS D90 ST. If at all possible, I'd love to keep the integrity of design, square lights. I googled and searched this forum up and down and found nothing. Any suggestions?
Old June 13th, 2015, 01:02 AM
search rubbolite here and you should find your answer. For 1994 style there are only 24 volt variants (which won't work) if you're looking for large units to replace your current square ones. You can always go with a single-LED-bulb to replace your current one in each square, but that's probably not what you're looking for ideally.
Old June 13th, 2015, 01:03 AM
Swap out the standard bulbs for LED bulbs and keep the square lights.
Old June 13th, 2015, 01:05 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Ok cool. That should work as my lights are still in good shape. Any suggestions on bulb replacements?
Old June 13th, 2015, 01:17 AM
It had autocorrected to rebbolite - should be rubbolite
Old June 13th, 2015, 02:39 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
This. Even better if you paint the inside of the housings with silver paint rather than the black. It really improves the light output. But there's nothing wrong with the wiring on the '94's that warrants replacement.
Old June 14th, 2015, 11:38 AM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
If the LED bulb switch doesn't work out, there was a thread about a square replacement for '94 (it was actually done on a '93 110). They repurposed some square LED lights from Australia.
Old June 14th, 2015, 11:47 AM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
As others have said, just replace with high output WHITE LED bulbs and put back the square covers. White gives the best output. Don't buy the hype about using colored bulbs, they're poorly visible and one thing a defender needs at night is visibility.
The square ones in the US don't give enough output and are too small for the space. Not worth wasting a dime on IMO. Any other option is just way too pricey and not available in the US.
1994 Silver DEFENDER 90 NAS SW
Old June 14th, 2015, 05:59 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks for the awesome tips! Can anyone suggest what LED bulbs will plug-and-play?
Old June 14th, 2015, 06:49 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Subscribed. I am also curious.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old June 14th, 2015, 07:05 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
I've found the best source to be superbrightleds.com. Check this out https://www.superbrightleds.com/more...ofit-car/1326/
A bit pricey but the light output, essentially permanent, and plug n play, made it worth it IMO. I got these 1156 for all ext lights except the side marker lights. The car finder worked pretty well if you want to be fancy..
Old June 14th, 2015, 07:13 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Originally Posted by drdread View Post
I've found the best source to be superbrightleds.com. Check this out https://www.superbrightleds.com/more...ofit-car/1326/ A bit pricey but the light output, essentially permanent, and plug n play, made it worth it IMO. I got for all lights except the side marker lights. The car finder worked pretty well.
It looks like the brake, turn, and reverse light is same bulb, right? I've never opened them to see.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old June 14th, 2015, 07:17 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
correct. everything but the side marker lights, which use those cylindrical small lights with connectors on both ends.
Old June 14th, 2015, 08:22 PM
curry's Avatar
curry
brandon curry
Series 1 and 110.
This place is much cheaper that superbrightleds. Only issue is, I've been trying to order from them forever with no luck: Mail Order Land Rover and 4x4 Parts | Outbound 4x4
Old June 14th, 2015, 08:44 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
I think you'll need way more than what comes in that "set", and I think the 1156 are the best bulb for every application (except the markers as I've said above), so to make it more apples to apples, price it out using mostly 1156s, the side marker bulbs (I think license plate are the same), shipping, and then reliable US based supplier vs. "not answering". IDK, check around here first. Maybe superbrights don't have the best price now, but they seemed to be the best/most reliable US based guys when I bought last year. Ebay has a bunch of cheaper guys but not knowing shite at the time I needed a seller who would work with my ignorance.
Old June 14th, 2015, 08:49 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Does anyone have first hand experience to say these are brighter than the incandescent they are replacing?
Old June 14th, 2015, 08:52 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Al, did you buy the ones on the web page you referenced? If so, was it true plug and play, or did you have to have a flasher or load resistor?
Old June 14th, 2015, 09:45 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Russell and Matt
Yes and Yes
Get the highest lum (which is why they are a bit pricy, but they'll blow away the crappy LR incandescent), and they just plug and play. Don't forget, the benefit of our older vehicles is there's less electrical shit to be tripped up. I did not need any resistors or receive the rapid flashing error.
Old June 14th, 2015, 09:52 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Russell and Matt
Yes and Yes
Thanks for the info. You have any pics? Not that it makes a big difference, as I will be replacing mine anyway.
Old June 14th, 2015, 10:26 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
I'm interested too
Square LED DMSLongLake Defender Technical Discussions 12 November 19th, 2013 09:49 AM
How to Convert 1994 rear Square Lights to 95-97 LED lights FlaD90 Defender Technical Discussions 7 November 20th, 2011 05:34 AM
LED Options kevkon Defender Technical Discussions 27 August 2nd, 2011 12:34 PM
Square D-90 clock easy Wanted 9 May 8th, 2005 09:33 AM
94 Square Tail lights switch to 95/97 ?? mfreeman17 Defender Technical Discussions 12 May 17th, 2004 04:58 PM
