94 Defender Tail Light Issues - Defender Source
Old May 1st, 2012, 11:39 AM
Defender_90
Kevin Doonan
1999 RR HSE
Hello all,
I am having issues with my drivers side tail light. The brake and indicator lights work fine, but I am having real issues with the running light.
Now this is an issue because I do not much feel like getting pulled over.
Anyone have an insite? is this an on going D-90 issue?
KD
Old May 1st, 2012, 12:11 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by Defender_90 View Post
Hello all,
KD
Could you clarify the light? Is it the red rectangle marker light on the side or the adjacent red tail square light on the rear? Good news, if one works, but not the other, your issue will be limited to the short wiring harness of the problem light as the both run from the same harness. Start by measuring for +12v at the receptacle then trace back to the two barrel connectors.
Old May 1st, 2012, 12:35 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
I had the same problem on the passenger side. I had 7v at the socket and 11v at the connector behind the right rear speaker. Cleaned out the connector and the light works now.
Old May 1st, 2012, 01:26 PM
Defender_90
Kevin Doonan
1999 RR HSE
It is the adjacent light on the rear. Can you give me some basic instructions on how to remove the light? Or anyone?
I just bought the truck and well as I am learning it is a money pit having people do the work for you and I am ready to start being alot more hands on, just need a little help from the board!
Thanks guys,
KD
Old May 1st, 2012, 01:36 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
It could just be the second element in the bulb (1157)
The gasket around the lens just peels off and you can remove the lens and bulb. No screws or clips.
------ Follow up post added May 1st, 2012 10:41 AM ------
Try replacing the bulb first then check the connections and voltage at the socket. Then trace the wire to the connectors.
Red wire/black stripe.
Old May 1st, 2012, 01:45 PM
Defender_90
Kevin Doonan
1999 RR HSE
Try replacing the bulb first then check the connections and voltage at the socket. From there the harness goes to the passenger side up under the wheel well behind the speaker. I forgot the wire color. The RAVE .pdf is invaluable for showing the routes and colors of all the wires.
Where might I find this RAVE.PDF?
And so basically I just pull back the rubber housing from the lens? easy as that?
Old May 1st, 2012, 01:54 PM
Save this as a favorite in your browser and on your smart phone if you have one.
http://www.internet-tools.co.uk/land...l%20(1993).pdf
And if you ever buy a 1997:
http://www.internet-tools.co.uk/land...l%20(1997).pdf
Old May 1st, 2012, 01:56 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Easy as that.
Old May 1st, 2012, 02:33 PM
Defender_90
Kevin Doonan
1999 RR HSE
Thank everyone for the help, I am going to look into this today and hopefully get it squared away with messing anything up.
Old May 1st, 2012, 10:24 PM
Defender_90
Kevin Doonan
1999 RR HSE
Thanks everyone. I sorted out the issue with the tail lights. Turns out that the issue was a bad connection at the bulb. After taking off the lens I went out and bought a new replacemtn bulb and it worked perfect. Happy to avoid getting pulled over for now.
KD
Old May 1st, 2012, 10:27 PM
Nice work Josh...I was/am in need of this as well, big help on this end too.
On a related note...you have access to the NAS wiring diagram/schematic? Got to sort my turn signals/hazards.
ht
cheaper rear tail light assembly RyanB16 Misc. Chit-Chat 6 January 28th, 2011 06:53 PM
95 tail lights on a 94 tub - possible? CDeWan Defender Technical Discussions 21 May 31st, 2010 08:17 AM
94 Defender 90 red mstrjake138 For Sale - Vehicles 3 January 12th, 2010 01:46 PM
rear tail light bulb socket. RyanB16 Wanted 5 March 30th, 2009 02:57 PM
94 defender 90 w/ 27k miles ebanks For Sale - Vehicles 5 September 8th, 2004 01:05 PM
