94 Defender flooding - Defender Source
Old June 4th, 2014, 03:15 PM
wesley0620
Wesley Everett
1994 Defender 90
Jun 2 at 12:40 PM
I have a 1994 Defender 90 with a starting problem. When cranking in the morning the engine will spin without cranking, after about 30-45 seconds it will fire (apparently only on one or two cyls) continuing cranking and it will eventually run on all 8 cyls and when it does crank it will blow a dark gray smoke for about 3-4 seconds. At that point the engine will run seemingly well and if you crank it about every hour or so it will crank up, however if it sits for 4-5 hours the same thing occurs. To this point I have changed the plugs, wires, cap and rotor and the fuel pump. This Rover has only 76000 miles and has been serviced. I have gotten to the diagnostic display and there are no codes and the check engine light is not activated. After changing all the parts and still having the same problem, I pulled the plugs and checked for good spark at the plug, (good spark there) but the plugs were all black and wet and smelling of gas so apparently it is flooding the cyls with too much gas. Has anyone ran across something like this? One more thing I removed the IAC (not sure if that is what it is called in Rover language) and cleaned and reinstalled, no help there then while it was running, I pulled the electrical connection from the IAC and the engine didn't change NOR did the check engine light come on even though the connection was off. I am a mechanic but I need technical advice.
Old June 4th, 2014, 03:26 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Read these threads to see if they help:
http://www.defendersource.com/forum/...ead.php?t=7619
http://www.defendersource.com/forum/...ad.php?t=10950
Old June 4th, 2014, 04:31 PM
injectors?
Old June 4th, 2014, 05:25 PM
I have seen this twice. Once was water in the ECU causing injectors to fire and flood the engine. The other time it was multiple leaking injectors. I would check the ECU first. It could be other things too.
Old June 5th, 2014, 01:09 PM
wesley0620
Wesley Everett
1994 Defender 90
After checking for wet ECU I began to look for the temp sensor that signals the ECU, there is nothing plugged into that sensor. Front of engine near thermostat, no wires that had been unplugged, just two male prongs sticking out. This D90 had been running fine without that connection. Still stumped about no code shown or check engine light.
Old June 5th, 2014, 01:40 PM
One temp sensor is for the AC so if you dont have AC it would not be hooked up.
Old June 5th, 2014, 01:46 PM
when mine was flooding it was a timing issue. Not sure if you somehow adjusted it and just forgot you had, but just in case it jogs your memory of something you may have changed.
Old June 5th, 2014, 02:37 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
+1
Definitely put this high on your list.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Colorado flooding solarguy Misc. Chit-Chat 11 September 14th, 2013 08:39 PM
Engine flooding with key on... Davis Defender Technical Discussions 6 October 31st, 2011 03:20 PM
One bank flooding out Defenderbuser Defender Technical Discussions 5 June 16th, 2009 07:48 PM
when engine off..flooding? HELP D90user Defender Technical Discussions 20 April 25th, 2006 12:59 PM
