94 Defender 90 cranks but won't start - Defender Source
Old September 8th, 2009, 07:39 PM
Charles LF's Avatar
Charles LF
Charles Fuqua
1994 Defender 90
Exclamation 94 Defender 90 cranks but won't start
My Defender (5 speed manual) ran perfectly and turned it off. Next day, went to start and it just cranks but won't turn over. I changed the fuel filter and when I turn on the ignition key, I hear the fuel pump run for about 5 seconds. I replaced the plug wires due to some corrosion and checked the plugs for spark. Got a redish spark. I checked the ODB at the passenger foot well but it is not displaying any codes, just dark. Only when I turn on the key to the accessory position and ready to crank, the check engine light comes on with a few others and then it goes off after about 5 seconds, lik eits simply doing a light check. I have a diagnostic scanner but I can't see where to hook it up. Is the 94 Defender OBDII? I see that OBDII started in 96. I do have factory A/C. Any ideas?
Old September 8th, 2009, 08:07 PM
Does it try to catch at all? Do you smell gas? Did you have a check engine light before the indicdent?
Did you try replacing the silver relays?
It is not OBDII.
Old September 8th, 2009, 09:11 PM
Charles LF's Avatar
Charles LF
Charles Fuqua
1994 Defender 90
Doesn't catch at all, just cranks. I smell faint gas after cranking for a while buit I don't remember seeing the check engine light on at all before this.
Old September 8th, 2009, 10:59 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
Sounds like the exact symptom I had in with my '94. First time it was a bad ignition module- a common failure, especially if it had not been relocated from the distributor.
The second time it would not start (just weeks after replacing the ignition module) it turned-out to be the pickup inside the distributor which I was told, rarely fails. Lucky me.
I wish I could tell you how to troubleshoot this but all I did was giagnose that I had no spark at the plugs and only one initial spark from the coil upon cranking. I left the rest up to my local mechanic.
Hope this provides some help.
Cheers,
CARL
Proud restorer and former owner of '94 NAS D90 #590- back in the hands of its original owners.
And now happy owner of a 1988 Swiss-Market D90 Station Wagon.
Old September 9th, 2009, 05:57 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Original or aftermarket coil?
Old September 9th, 2009, 02:17 PM
Green Blood
Carl Phillips
My ignition coil is the standard Bosch unit. Waiting for it to fail next.
Old September 9th, 2009, 02:43 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
diconnect battery to reset ECU, this has worked for me in the past.
90, defender 90, start
94 Defender 90 POE $22000 parkcity4x4classic The Flea Market 4 July 28th, 2008 11:46 PM
1995 defender 90! TwisteD90 For Sale - Vehicles 38 November 4th, 2004 10:15 AM
UK defender 90 110 130 brochure mpodgorski For Sale - Parts 1 June 25th, 2004 02:13 PM
For Sale 1997 Defender 90 djshepard1 For Sale - Vehicles 2 March 28th, 2004 09:12 PM
1994 Defender 90 charliefc For Sale - Vehicles 0 February 1st, 2004 02:23 PM
