94 D90 with "Hard" brakes - Defender Source
Old September 2nd, 2014, 04:22 PM
crash05
CJ Szpila
1998 D1 /1994 Defender
I got my 1994 D90 about 2 years ago and ever since I have had it the brake pedal is very hard. I am thinking that the brake booster might be shot. Is this a common thing? How hard is it to change out? Thanks
Old September 4th, 2014, 04:56 PM
crash05
CJ Szpila
What about the brake booster?
Old September 4th, 2014, 04:59 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I wouldnt say common, but it is 20 years old.
-Jeff
Off topic, but holy beagle attack in your avatar :
Old September 4th, 2014, 05:15 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
On topic
I know brake fluid can become hydrolyzed, its not often changed and opinions on service intervals vary. Might be worth having a shop completely drains and bleed the calipers, shouldn't be an expensive job (as materials are cheap).
Might also be a stuck caliper or a caliper that has frozen open, if you lift it you should be able to inspect each caliper with the wheels on (just apply brakes and spin the tires to see if they are grabbing)
Old September 4th, 2014, 07:59 PM
crash05
CJ Szpila
How do you check the booster?
Old September 4th, 2014, 08:36 PM
Push your foot hard on the brake with the engine off ... Start the engine and you should feel your foot sink further if it working.
Old September 4th, 2014, 10:07 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Sound advice; easy way to check
Old September 5th, 2014, 04:28 AM
crash05
CJ Szpila
Is it a pain to change out?
Old September 5th, 2014, 08:18 AM
It's pointless to even think about it until you've tested it ...
Old September 5th, 2014, 09:46 AM
Rommel's Avatar
Rommel
Rolf
94/95/97 Many
Hard pedal
We have seen this problem a number of times in our shop one of which was my own POE as others have said bleed brakes completely checking for good flow from all calipers,brake master or booster is possible but mine was the portioning (sp). Valve mounted on the pass side of firewall,slide valve was stuck,after replacement brakes worked like a charm.
Rolf
rolfsauto.com
Old September 5th, 2014, 10:59 AM
most likely bad calipers. wheels off, check the pistons all move. not that hard to do really. You'll need a jack, a jack stand or two, a lug wrench, and a big screwdriver or pry bar.
90, brake, d90
"Stinky" or "Reddy" (named by Daughter) :: 1985 Land Rover d90 pitchrollyaw Defender & Series Truck Registry 5 July 4th, 2014 04:37 PM
" Wolf " Style Steel Rims 6.5" X 16" 2 3/4" javelinadave For Sale - Parts 3 January 27th, 2014 08:36 AM
squealing brakes on 94 D90 NAS BadMonkey Defender Technical Discussions 3 October 31st, 2012 10:35 PM
Formula R1X Disc Brakes - Mountain Bike Brakes bjf The Flea Market 4 May 14th, 2012 10:07 AM
86 D90 Brakes, Specs? Larns Defender Technical Discussions 4 June 9th, 2004 06:55 AM
