94 D90 with fast turn signals. - Defender Source
Old December 27th, 2012, 04:09 AM
crash05
CJ Szpila
1998 D1 /1994 Defender
I just recently got a 94 D90. The past owner replaced the front bumper but decided to leave out the turn signals in the bumper. Now when you turn them on the have a fast blink and clicking noise. The kind of noise you get if you have a bulb out. Is there a different relay I can use to slow them down?
Old December 27th, 2012, 04:37 AM
Does it have front turn signals at all? If you hook up lights the flashing will go back to slow.
Old December 27th, 2012, 08:29 AM
rovertrader's Avatar
rovertrader
Dale
Some folks deleted those bumpers and associated lights, then wired in the lower round yellow as a turn signal like the 95s.
Old December 27th, 2012, 08:33 AM
The Dro
Dro
1988 Ninety
You can fix that by replacing the relay....
Do a search here or on Dweb. I cannot remember where I read it.
Old December 27th, 2012, 09:52 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I did the very same mod and now have fast flashers. Guess the resistance of the bulb for the bumper is different from the 94' running light. Thinking the 95' uses a different bulb? At least the lens is a larger dia.
Old December 27th, 2012, 10:35 AM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
I had the same issue- replaced all the bulbs for the turn signals with 7506s. Problem gone.
Cheers
Jay
Old December 27th, 2012, 10:51 AM
down_shift's Avatar
down_shift
Russell
Cheers
Jay
You da man. Will grab a handful today.
Old December 27th, 2012, 11:02 AM
bjf's Avatar
bjf
barry f
94 ST #395
Did they actually move the turn signals to the parking lights or do you have no signals in the front? If they moved the signals than it may be as simple as a bulb but if they didn't then it is likely the missing turn signals causing the issue. There is a wrote up on here that will explain how to correct it.
Old December 27th, 2012, 11:31 AM
CDeWan
Clay DeWan
5.3L beastie
Did the same mod and made the lower running light the turn signal with a yellow bulb. I didn't run into any fast blinking (which is a sign that the bulb is out).
Old December 27th, 2012, 11:18 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Here's the relay write up on Dweb:
http://www.discoweb.org/blinkers/index.htm
I did this when I deleted the rear bumper lights on my D1.
Old December 28th, 2012, 12:30 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
The bulb from the turn signal will fit in the socket. That all that was done when I moved them from the bumper before I put my winch bumper on.
Jimmy Buffett
Old December 28th, 2012, 01:22 PM
maleger
Marc-Andre Leger
I also rewired the lower running lights as flashers. I converted them to LED and added a resistor I got off ebay to compensate for the resistance issue. I used heat shrink and electrical tape to make a nice clean installation. About an hour job to do it right. You need to remove the passenger side headlight to get to the connectors on that side, but can get to the driver's side cables with some fishing around and a little patience.
90, d90, signal
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
