94 D90 stalling when load put on the engine - Defender Source
Old May 13th, 2007, 02:08 PM
makof-16
Brent Caswell
1994 D90
I washed my D90 and when I started her back up and went to drive away she died. I was able to drive home but had to keep the RPM at 2000. After she sat for 6 hours I checked (from reading the other post) and my ignition cable is moved to the ds wheel well and the white ignition cable that is behined the engine is dry. I also pulled off the distrbitor cap and everything appears dry. She will start but any time I put any load on her (in gear or turn the a/c on) she dies! any ideas?
if not, does anyone know a good mechanic in the Homestead FL area? Thanks for the help!
Old May 14th, 2007, 09:13 PM
Brent, spray some wire-dry or wd-40 on the coil and other electrical components even if they appear dry. If this just started after washing it, I'll bet that's all it is.
hth
charles
Old May 15th, 2007, 07:52 PM
makof-16
Brent Caswell
1994 D90
Thanks Charles- I'm not so good with cars, where exactly is the coil?
Old May 15th, 2007, 08:29 PM
It's a little cylinder roughly the size of a can of shaving cream, located on the driver side wheel well. It has a wire running from it to the center of the distributor cap.
Spray any thing that remotely looks like it's electrical - you can't hurt it with wd40
charles
Old May 27th, 2007, 11:51 AM
makof-16
Brent Caswell
1994 D90
Unhappy
Well, I thought the Wd-40 helped -- it would run fine for about ten minutes then when I'd push the clutch in the rpm would drop to idle then stall. After getting it restarted it would do that a few more times then run fine. Today I walk out to drive it and it wont start! Help! has anybody been to a good mechanic in the homestead/ miami area?
Old May 27th, 2007, 12:12 PM
Joeplumbo's Avatar
Joeplumbo
Joe PLumbo
1993 110
Hello Brent,
Had similar issues with my '95. Turned out it was the new LR rotor. Replaced with non genuine rotor and has been fine.
Should be 7-10 dollars.
Good Luck
Joe
Old May 27th, 2007, 06:16 PM
makof-16
Brent Caswell
1994 D90
Sounds good Joe,
What brand of rotor did you use that worked well?
Old May 31st, 2007, 08:23 AM
makof-16
Brent Caswell
1994 D90
Thaks for all the help- turns out it was a fuel pump / relay - $800 at the dealer. She runs great now though!
90, d90, engine
94' D90 ST, 55k miles LOWERED to 21.7k or BEST OFFER in CT. PIX link januconn92 For Sale - Vehicles 1 March 15th, 2004 09:46 PM
Driveline Clunk in early '94 D90 Hans Defender Technical Discussions 8 November 25th, 2003 09:43 PM
