94 D90 Power Steering Pulley - Defender Source
Old June 29th, 2016, 08:30 PM
vir2uosbze's Avatar
vir2uosbze
MARLON
1994 D-90 #560 Portofina Red
Just changed my water pump on D90 yesterday and I put it all back together. Started up the truck and now I have a wobbling pulley from my power steering. Everything was tightened and the truck was running perfectly fine before. Thinking the pulley is bent so I called everywhere but the pulley is out of stock and no longer made.
Old June 30th, 2016, 06:56 PM
ajtbussen
A J Bussen
1997 D-90 ST
Get a used one from a v belt Discovery. They are the same and there should be a lot of them around. Check with the rover breakers.
If it aint moto it's worthless.
Old July 1st, 2016, 07:48 AM
vir2uosbze's Avatar
vir2uosbze
MARLON
Thanks, will check on that and start stocking up on parts like this for my defender.
Old July 1st, 2016, 08:41 AM
ezzzzzzz
Mark Garrenton
Did you not notice the wobble before? I'm assuming that pulley wasn't removed. Check for play in the PS pump shaft itself. It could be the cause of the wobble. Just grab it and to check for any excess movement (you might need to remove the V-belt first). I didn't see a spare V-belt pulley in the garage. The shed holds a load of bits but digging into it is a nightmare. I'll let you know if I find one though.
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old July 1st, 2016, 02:20 PM
vir2uosbze's Avatar
vir2uosbze
MARLON
Everything was working perfectly fine until I removed and reinstalled the pulley. After I got done with the water pump install, the motor was started right after and it was running good that night. My problem happened the next day and that's when the wobble started. I started D90 and the power steering shaft spun smoothly. It is the pulley that wobbles. Thanks for the advice.
Old July 1st, 2016, 06:34 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
My Classic has a spacer between the pulley and studs. Any chance you forgot to install it assuming your truck uses one?
Old July 1st, 2016, 07:32 PM
fletchervt
noel bishop
87 110 3 door hard top
belt too tight?
Old July 3rd, 2016, 02:04 PM
vir2uosbze's Avatar
vir2uosbze
MARLON
Changed the power steering pulley and everything is running good now. The old pulley was starting to separate and that's why the wobble started. Thanks for all the pointers.
WTB: Pulley for steering pump on a 300TDI Kitlisle Wanted 2 April 27th, 2016 11:37 AM
Power Steering Pump Pulley for V belt ArlowCT Wanted 1 April 21st, 2016 08:12 AM
Power steering pulley? Vunkle Defender Technical Discussions 0 April 20th, 2015 02:38 PM
Crankshaft pulley for adding power steering jafir Wanted 0 November 2nd, 2013 08:50 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
