94 D90 POE Hard Top Removal - Defender Source
Old June 29th, 2007, 12:54 PM
EPMROVER
Eric May
1994 POE D90 Wagon
OK, I have owned the 94 POE wagon for about 3 months. Is the top easy to remove? Any tricks? Thanks for anyone's advice!
Old June 29th, 2007, 02:24 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
it takes 2 people to actually remove it from the truck, but only takes one person like 30 minutes to unbolt it. pop the back corners up and pull it back towards the rear of the truck.
one word of advice when putting it back on is to try to get the front pushed down and squared up first, because its a bitch if you line up the back first then try to pry the front edges over the roll bar in the front.
also use a bunch of washers to lift up the bold heads to the 6 or 7 bolts that hold the front of the top to the windshield. you know where im talking about? those little holes where the bolts go into and screw in? try to keep that bolt up high so that you can get to it easy to wrench it back out. I screwed some of those too far down and it was a pain in the butt to try to fit a wrench/socket or anything in there to unscrew it.
also when you have it off, you should drive it around the block for a quick minute. it's funny looking.
90, d90, hard top
FS: Winch/Bumper and fiberglass hard top for D90 aircraftguy For Sale - Parts 10 January 8th, 2009 09:32 PM
Removing Hard Top tron Defender Technical Discussions 2 March 30th, 2005 07:51 PM
Hard Top Questions ronward Defender Technical Discussions 4 November 9th, 2004 10:17 PM
D90 Hard top for sale k4rovers For Sale - Parts 0 June 26th, 2004 01:30 PM
