94 D90 ECU Replacment Options - Defender Source
Old July 14th, 2007, 01:38 PM
RBees
Robert Bees
1994 D90 #8
Does anyone know what the options are for replacing the ECU on a 94 D90 ? Getting an exact replacement will be both hard and very expensive, so I'm wondering if anyone can give me some input on the use of other ECUs that might be more widely avaiable and cheaper.
Old July 15th, 2007, 01:23 AM
bd90
94 Arles Blue #1644
I had to have mine replaced a few months back because moisture found its way in. The LR mechanic found a used one from a Discovery for $450 I think. A new one was @ $1200. He put guts from the new one into the housing from the old one and reinstalled. This was in Houston but it sounded as if he's done this before so I'm sure any LR mechanic would know to do the same. In fact you could probably do better that $450 if you found the ECU on your own. If you find an ECU from another LR, you will need the housing from your '94 because the ECU hookups are different. Later, Brian
Old July 15th, 2007, 06:50 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Robert,
I have a pile of used ECU's that will work.......if you can't get the old one dried out ok.
Matt Browne
90, ac, d90, ecu
Options for replacing '94 D90 CAT PCRover Defender Technical Discussions 2 July 17th, 2008 06:01 PM
D90 TD5 ECU Chip upgrade? Should I or not? adibitar Defender Technical Discussions 11 September 1st, 2005 01:22 AM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
Disco ECU works on D90? artm Defender Technical Discussions 3 November 27th, 2003 11:45 PM
