94 D-90 overheating!! - Defender Source
Old June 29th, 2012, 06:44 PM
Mowabb2
Garrett
1994 Land Rover Defender 90
I have recently had problems with my D-90 overheating. I got a new water pump and hoses, a new thermostat, got the radiator rodded out, and still don't know what is wrong. I have been told that the fan clutch might be the issue but i also was told that if I get the radiator fixed, I wouldn't need a new fan clutch because the radiator is big enough to cool off the engine alone. I have no idea what to do now, so if you have had a similar problem, please let me know because I would really like to keep this car! If I can't get it to cool down, I might have to get rid of it... It only gets hot when I am going up a hill or sometimes on the freeway... I don't know if that is normal or if that is really bad...
Old June 29th, 2012, 06:52 PM
Sensor defective?
Old June 29th, 2012, 07:21 PM
Grover's Avatar
Grover
Get a new fan clutch.
Old June 29th, 2012, 07:22 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
If it's happening at speed (freeway) and not at idle then it might not be the fan clutch, but you should test that with the rolled up newspaper to stop the fan from spinning once the engine is warm. If you can stop it, it's worn out and not engaging.
Sounds like you have opened up the cooling system a few times. Make sure all the air is out. It took me a few weeks to burp the last bubble out of my system after I had the radiator worked on. It was running a little hot, but only at low speeds and at idle.
Old June 29th, 2012, 07:25 PM
Originally Posted by Rocky
Sensor defective?
If it rises and falls under load then it's not the sensor.
First check the system pressurized and is full. The hoses should be firm after you've been running and should hold pressure for a while. Check the expansion bottle cap seals properly ... I've seen faulty ones.
Fan clutch is probably a good place to start once you've done this. Don't think a heavy duty is better than standard ... It will just make more noise and suck gas! ( ask me how I know! )
Make sure the system is well burped to get all the air out ... It's harder than you would imagine ...
Pressure test the system ... You can rent a pressure tester from autozone for free .. That will help locate any leaks.
Make sure that the radiator doesn't have any cold spots after running for a while ... You may have had it rodded .. But I don't trust anything I haven't validated myself.
A D1 fan clutch and an RRC 11 blade fan can beef up your cooling power a bit ...
If after all this you still have an issue then it's probably head gasket related ... I'm just about to do mine ...
Old June 29th, 2012, 07:32 PM
Grover's Avatar
Grover
I know this is obvious, but be sure it's topped off.
Do you have a temp gun? If so, check the temp difference between the upper and lower hoses.
Any leaks? Have you checked for exhaust gases in the coolant?
Cheers...
Old June 29th, 2012, 07:41 PM
CDeWan
Clay DeWan
5.3L beastie
I am on this soap box all the way. The coolant system needs to be put under vacume and then filled and it takes a special tool. I have overheated and had to resleve my 3.9 just because I did not have the system fully filled.
Old June 29th, 2012, 07:47 PM
Is it the freeway when in traffic or when you are moving?
Old June 30th, 2012, 09:23 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Also; fitting a proper aftermarket (VDO Vision are good and inexpensive and easy to install) temperature sensor and gauge that reads in actual degrees is something that really should be done on every vehicle. Especially considering the 'signal conditioner' that ECR points out on thier site.
Old July 1st, 2012, 03:15 AM
Mowabb2
Garrett
I think that the car just overheats when I go up the hill, I posted the original message after the first time I drove it after the radiator got fixed. I realized that it has actually gotten a little bit better but I will for sure try to burp the system out. Thanks for all the input and keep adding if you know more!
Old July 2nd, 2012, 12:22 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Check the head gaskets.
Jimmy Buffett
Old July 2nd, 2012, 01:24 PM
61rover's Avatar
61rover
John Crouse
unfortunately x2 on the head gaskets. That's how mine started.
90, d-90, overheating
94 Defender 90 NAS center console triple9music Defender Technical Discussions 1 June 28th, 2012 08:51 PM
stock 94 NAS 90 to Def 300 TDI/R-380, will I need new drive shafts? lrna04 Defender Technical Discussions 7 April 3rd, 2012 09:37 PM
94 Defender 90 red mstrjake138 For Sale - Vehicles 3 January 12th, 2010 01:46 PM
94 defender 90 w/ 27k miles ebanks For Sale - Vehicles 5 September 8th, 2004 01:05 PM
94 NAS 90 Owner's Manual JRowe Wanted 0 January 20th, 2004 11:03 AM
