'94 clutch and transmission question - Defender Source
Old January 31st, 2006, 01:42 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I am going to have my transmission rebuilt (R380), 2nd gear syncro is pretty much gone, and the grinding is getting to me. Obviously, replace the clutch too. Apparently there may be issues with wear on the input shaft due to no oil holes in one of the input gears? Can anyone clarify the problem and solution? I may as well deal with it if everything is out of the truck.
thanks!!
Old January 31st, 2006, 01:48 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
The issue is actually between the output shaft on the tranny and the input shaft of the transfer case.
Is your Defender really stamped #38? If yours is really that low, and you have an R-380, you'll probably already have the fix done to solve that. If you haven't, the input gear for the transfer case is a quickie drop-in and the rebuilt tranny will cover the transmission shaft.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 31st, 2006, 02:00 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
It's really #38. I have had it for 4 years now, but I don't have all the service records from the previous owner. The mileage is 265,000km (about 165,000 miles) so I would expect that the tranny has been out before.
What are the symptoms of the wear?
Knock on wood.... other than this, it has run perfectly since I have owned it.
Old January 31st, 2006, 10:04 AM
jstrong98's Avatar
jstrong98
Jon Strong
I thought the badge #'s were not indicative of when it was produced. I remember reading that they were randomly put on the truck as they were imported ?
I may be wrong.
JS
Old January 31st, 2006, 01:32 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I think the numbers are in order, but not sequential with US and CDN models. If you check out the registry, it looks like there are some numbers between what was listed for North America. Possibly models that were exported to other countries.
http://www.fourfold.org/LR_FAQ/Defen...nder_VINs.html
clutch, transmission
Clutch pipe question RiftRover Defender Technical Discussions 7 October 2nd, 2009 04:58 PM
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
Transmission or Clutch prob?? kiefffff Defender Technical Discussions 4 June 29th, 2006 10:55 PM
Lifting engine and transmission together?? cbass Defender Technical Discussions 5 November 7th, 2005 06:23 AM
Transmission clicking? oldscratchggf Defender Technical Discussions 1 June 14th, 2005 06:42 AM
