94 Camber issues - Defender Source
Old June 2nd, 2007, 08:18 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
94 Camber issues
I just purchased a 94 D90 and I drove it some 1200 miles home and I've noticed that the tire wear is far from even. It is exhibiting what I believe is a negative camber situation, i.e. the tops of the wheels are closer to one another making the inside edge of the tire wear faster. If anyone can offer a possible explanation why this is happening and a possible solution I would appreciate it. The driver's side is worse than the passenger's but they are both pretty bad. Looks like I'm going to need a new set of front tires because of this problem and I don't want to put a set on until I fix the problem.
Sean-Paul
Old June 3rd, 2007, 12:02 AM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
It is more likely to be toe-out than camber - where the front wheels do not have sufficient toe-in. This condition is usually accompanied with understeer, a tendency to wander from center and the steering wheel not returning to center on its own when moving. Ruined tires but a simple front wheel alignment should fix it.
Owen
Old June 3rd, 2007, 12:15 AM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
Owen,
You named all of the symptoms I'm having. I was headed to Sears in the morning to have an alignment done hopefully that takes care of it.
S-P
Old June 3rd, 2007, 01:42 PM
owen's Avatar
owen
Owen Jones
Great Sears should not only fix it but give you back a truck that is very well mannered and a joy to drive!
Best,
Owen
Old June 3rd, 2007, 02:28 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
It's definitely a joy to drive even with the wandering steering. I did find out it can't be aligned because the drop arm is shot and I need to replace that before it can be done. Oh well for a 13 year old rover it's not too bad.
S-P
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Server issues chrisvonc Support & Suggestions 4 June 16th, 2005 01:17 PM
EMERGENCY-Xfer case issues Cyborg Defender Technical Discussions 7 July 18th, 2004 02:50 AM
Getting Help, Outstanding, & Known Issues chrisvonc Support & Suggestions 0 May 23rd, 2004 06:00 PM
battery/ electrical issues steve_brooks Defender Technical Discussions 1 April 23rd, 2004 04:05 PM
